external graphics card , what cable?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by ritfin, Apr 23, 2017.
  1. ritfin
    ritfin Newbie
    Hi,
    What cables do I use for external graphics cards? I have a laptop
    would usb 3.0 or hdmi work for graphics card
    here is laptop plugs;
    Left side: Mini FireWire, RJ-45 Gigabit LAN, 2x USB 3.0, eSATA / USB 3.0, 9-in-1 card reader
    Back: Kensington lock, DisplayPort, HDMI, Mini DisplayPort, power jack
    Right side: optical drive, 4x sound, USB 2.0
  2. Starlight5
    Starlight5 So what if I'm crazy? The best people are.
    @ritfin neither of those would suit for eGPU. It may be possible to use WLAN slot, but it's not comfortable, and may not work at all. However, if you just need to add an extra monitor, without intent to play games on it, a USB 3.0 to HDMI adapter will do.
  3. ritfin
    ritfin Newbie
    @Starlight5
    so your telling me that out of the plugs below there is no option for a eGPU? thanks.
  4. Starlight5
    @ritfin yes, that's what I'm telling you. None of the ports you mentioned are suitable for the task; only your Wi-Fi card slot can be. I's either mini PCIe or m.2 a-key, has pcie bus either way.
  5. TomJGX
    TomJGX I HATE BGA!
    Agreed, options are limited unfortunately!
