Ext. USB Harddrive question.
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Mr. Miller, May 8, 2008.
  1. Mr. Miller
    Mr. Miller Notebook Enthusiast
    Could I run programs on an external USB harddrive?
    Thanks
  2. chipmoney
    chipmoney Notebook Evangelist
    Yah, I have most of my games installed on an external drive and they run fine :)
  3. The_Observer
    The_Observer 9262 is the best:)
    Is it slower in loading or something?
  4. sgogeta4
    sgogeta4 Notebook Nobel Laureate
    it depends on what interface you are using. eSATA should not experience much slowdown compared to internal hard drives, while firewire and USB would due to their bandwidth restriction.
  5. powerpack
    powerpack Notebook Prophet
    What are you wanting to run? Yes you can use it but as said with the common interfaces USB/firewire it is substantially slower. For file storage it is fine. Remember it is still faster than your optical drive and those can play blu ray video.
  6. garetjax
    garetjax NBR Freelance Reviewer NBR Reviewer
    Was there a particular external hard drive you were looking at purchasing? I have a particular hard on for the Silverstone Treasure TS01B external 2.5" HDD enclosure.
  7. goofball
    goofball Notebook Deity
    You could definitely run programs off of it, but just ensure that the drive letter does not change as some programs make static entries in the registry and include the drive letter as part of the info.
