Excellent performance on Ge75, 2080 and 9880H - 8 cpu
Discussion in 'MSI' started by jks87, May 29, 2019.
  1. hackness
    hackness Notebook Virtuoso
    Cool, bumping up the core clock means having the frequency to run at a higher level for each voltage, for example:
    Before OC'ing the Core clock, let's say at 0.743V, you maybe running at 1455MHz, after you have added +150MHz to the core clock, you maybe running at 1605MHz @ 0.743V, usually the temperature and the power is largely affected by the voltage, not the frequency, which means you'll have a better energy efficiency when you bump up the core clock and the temperature wouldn't increase much. But if you have gone too far, the voltage isn't sufficient enough to run the core at that frequency, the driver will reset itself and you need to re-tweak again, then you know where is the limit for your GPU at that voltage. The ultimate goal here is the find the most energy efficient frequency you can get for the common voltage you'll come across in your everyday gaming session.
    This also means more output even the TDP limit of the GPU is met.
    Edit:
    About the memory clock, by bumping up a few hundreds, you might see the temperature increase by 1~4 degrees, it depends on how far you go, if the temperature is controlled under 80 I'd just go all out.
    If you find out you are getting runtime errors reported when playing a game, that means you have gone too far increasing the memory clock, usually runtime error comes before broken texture for the memory clock, so it's easy to know.
    ryzeki and Gr4dy like this.
  2. Gr4dy
    Gr4dy Notebook Enthusiast
    It seems the 9880H provides a huge leap in score beyond the 9750H. Even with my 2080 OC'd, I can't even come close to a 20k Firestrike score.
  3. Kriegprojekt
    Kriegprojekt Newbie
    How have the thermals been since you bought this? Are you seeing decent temps since then? Are you still happy with the product?
  4. Porter
    Porter Notebook Virtuoso
    What machine do you have? Even a bone stock 8750H with 2080 scores above 20K fire strike.
  5. Gr4dy
    That can't be true. My laptop specs are in my signature.
  6. Porter
    OK, sorry you didn't say maxq 2080 so I assumed it was a full one. I was on mobile so signatures don't show up but I see it now on my pc.
  7. Gr4dy
    Ah, yeah, sorry. This thread kind of got sidetracked on discussing GS75s and they only come with a Max-Q at their highest GPU.
    Porter likes this.
  8. dhaupert
    dhaupert Newbie
    Hey there. Thanks for posting these numbers. Did you ever run with an OC and if so what were the numbers and temps? Very much thinking about this config for my next purchase!
  9. Kamzan
    Kamzan Notebook Deity
    My alienware area 51m got burned as well, now like u, im thinking on getting the ge75 raider with 2080, though the alienware 51m had a 2080 desktop class gpu inside. How much in performance do u think i will lose if i go with the ge75 raider?
  10. Porter
    The 2080 in the GE75 is also a full powered GPU. In theory they should be about the same, even with overclocking. The GPU cooling in the GE75 is great although likely behind the larger Alienware. Power is one thing I don' know about, only if the GPU has a much higher power limit would it have more GPU capability.
    Now CPU wise, it would be a hit going form a high end desktop CPU to the BGA cpu for sure. Guessing off the top of my head maybe 20% less stock vs stock. Overclocking the desktop CPU would only make that a wider range. In my opinion, veyr few games are CPU bound, none of the games I play are so I can't speak about FPS differences.
