Excellent performance on Ge75, 2080 and 9880H - 8 cpu
Discussion in 'MSI' started by jks87, May 29, 2019.
  1. undervolter0x0309
    undervolter0x0309 Notebook Consultant
    Thanks for posting! What are the Cinebench r15/r20 scores? I'm curious how the 14nm size is doing with 8 cores in a relatively small package.
  2. kothletino
    kothletino Notebook Consultant
    You mean "stock" not "full" right?
  3. ryzeki
    ryzeki Super Moderator Super Moderator
    He means that idle speeds, when using 100% fans, are very low.
    custom90gt likes this.
  4. kothletino
    Quite a misunderstanding, hahaha sorry...
    Speeds or temperatures?
    So once again slowly ;D
    The i9-9880h which he has, stays in the temperature range 35°-39°, while idle with the fans @ full speed? If this was the point, then sorry but it's not very cool and cold.
    What is the stock temperature, and rpms of the cpu fan in idle then?
  5. jamesoth
    jamesoth Notebook Enthusiast
    Can I know which 90W vbios you flashed? I also got a GS75 2080MQ and 9880H. I flashed a razer one and clock speed did not change and not able to turbo.
    sorry to hijack a GE75 thread.
  6. iunlock
    iunlock 7980XE @ 5.4GHz
    I was going to DM you but figured I'd just reply here. :) To clarify, I'm using the stock drivers and bios. The version can be found here.
  7. MorphineX
    MorphineX Notebook Enthusiast
    Can you run firestrike / timespy again with the laptop unplugged from ac adapter please?
  8. jamesoth
    I'm on the same stock EC firmware as well and got 20k in firestrike graphics. And I am running on turbo mode with a 100mhz overclock.
    hmmmm.
  9. ryzeki
    In theory the new GS75 already had 90w vbios, so you need to revert back to your stock vbios and test again. I am using the razer 90w one and I have the same score as you (20k). Did you test or saw the clocks of your stock vbios before you flashed?
    toughasnails likes this.
  10. hackness
    hackness Notebook Virtuoso
    The 9th gen GS75 does have a 90W vbios, good news for cross-flashing, a MSI 90W vbios. :)
