Excel: how to keep table header in place?
Discussion in 'Windows OS and Software' started by hendra, Mar 16, 2010.
  1. hendra
    hendra Notebook Deity
    How do I keep the first row of Excel, the table header, to stay in place while dragging the scroll bar down?
  2. lbohn
    lbohn Notebook Consultant
    Window > Split
    Drag the pane borders to set the static rows and/or columns.
    After you set the static rows/columns, you can continue using Excel with the large pane borders or use Window > Freeze Panes to set the view and "hide" the borders.
    --L.
  3. hendra
    Thanks. It works! :)
