Europe AC Laptop Power Cord For Dell
Discussion in 'Dell' started by zogthegreat, May 10, 2019.
  1. zogthegreat
    zogthegreat Notebook Guru
    Hi everyone!
    My gf is sending a Dell Latitude E7450 over to her parents in Europe. Does anyone have the Dell part number for Europe AC Laptop Power Cord?
    Thanks!
    zog
    (EDIT) just to mention, the power supply is a Dell 3-Prong AC Adapter - 65 Watt, Dell P/N: JNKWD .
  2. Kyle
    Kyle JVC SZ2000 Dual-Driver Headphones
    In case you did not know, you can just get a generic plug adapter (US->EU). More versatile since you can then use it for all US plug types - HP/Dell/Lenovo/Asus....
  3. zogthegreat
    (chuckle) Thanks Kyle, but her parents are in their 70's and have had trouble with the plug adapters before, (how, I will never understand!).
    That's why I want to simplify things and just get the proper cord.
  4. User32
    User32 Notebook Deity
    Just go to a random thrift store and look if they have a three-prong "Mickey Mouse" cable with a EU plug.
  5. dave-p
    dave-p Notebook Deity
    eBay has them, Amazon has them
  6. heretofore
    heretofore Notebook Consultant
    In EU (outside UK), this is the US to EU adapter I use with my US laptop.
  7. DoctorRzepa
    DoctorRzepa Notebook Guru
    With no ground pin? That's rather unsafe.
  8. heretofore
    The standard European plug/socket has no ground pin.
    Ground pins vary in Europe.
    https://en.wikipedia.org/wiki/AC_power_plugs_and_sockets
    In a worst case situation, what would happen if the laptop internally shorted?
    You could get a 20V DC "shock" by touching the laptop exterior (which is often plastic but could be metal).
    If the AC to DC adapter shorted and sent 220V AC into the laptop, I imagine there would be smoke/fire, with or without a ground plug.
  9. DoctorRzepa
    It is your choice. Someone designed power brick to use ground pin. As I suppose, there is a reason for that. Not only keeping your notebook from power supply failure, but also protecting you from electric shock in case it gets damaged. Better safe than sorry.
  10. heretofore
    The ground pin does not prevent failure of the power brick.
    I could be wrong but I believe there are fuses in most/all notebook power bricks.
    Do you know even one example of a notebook power brick that shorted and electrocuted someone?
    I have never heard of such a thing under normal conditions (not wet, not physically damaged)
    At 20V DC, you will feel little or nothing, under normal conditions (not wet and so on)
