Eurocom sky x4C (P750TM1-G) and apple thunderbolt issue
Discussion in 'Sager and Clevo' started by malo sasha, Feb 23, 2020.
  1. malo sasha
    malo sasha Newbie
    Hi
    I m struggling to get an apple thunderbolt display to work with my eurocom sky x4C on linux .
    The chipset on the X4C is alpine ridge and should be compatible. I updated from a windows dual boot to the latest thunderbolt driver available on driver page.
    However i cant get the display to turn on.
    here are a few commands that display the issue :
    lspci :
    03:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
    04:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
    04:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
    04:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
    04:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
    05:00.0 System peripheral: Intel Corporation JHL6540 Thunderbolt 3 NHI (C step) [Alpine Ridge 4C 2016] (rev 02)
    39:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
    dmesg | grep thunderbolt
    [ 34.795395] thunderbolt 0000:05:00.0: Max hop id (in/out): 9/9
    [ 34.795395] thunderbolt 0000:05:00.0: Max counters: 2
    [ 34.795395] thunderbolt 0000:05:00.0: NFC Credits: 0x1000000
    [ 34.795498] thunderbolt 0000:05:00.0: Port 11: 8086:15d3 (Revision: 6, TB Version: 1, Type: DP/HDMI (0xe0102))
    [ 34.795498] thunderbolt 0000:05:00.0: Max hop id (in/out): 9/9
    [ 34.795499] thunderbolt 0000:05:00.0: Max counters: 2
    [ 34.795499] thunderbolt 0000:05:00.0: NFC Credits: 0x800000.
    [ 34.796596] thunderbolt 0000:05:00.0: switch at 1.1 was rejected by ICM firmware because topology limit exceeded
    [ 34.796598] thunderbolt 0000:05:00.0: switch at 2.1 was rejected by ICM firmware because topology limit exceeded
    I tried various thunderbolt BIOS options , especially setting Enumeration mode to Legacy and Security to Legacy bit always the same error message
    At that point i think the issue is coming from the nvm version on the thunderbolt chip that looks too old :
    cat /sys/bus/thunderbolt/devices/0-0/vendor_name
    CLEVO
    cat /sys/bus/thunderbolt/devices/0-0/nvm_version
    23.0
    Did anybody manage to get the monitor working or knows how to update the NVM safely on the chip ?
    Best REgards
  2. Ryan Russ
    Ryan Russ Notebook Consultant
    So there are a couple of options in the BIOS that need to be looked at or switched. One such option is mdp routing through tb3. Forget exactly the area, but that was the one I had to personally check.
  3. Meaker@Sager
    Yep, you can have the signals routed to the displayport ports or the thunderbolt ports individually (ie you can have one dp and one TB port with dp)
  4. malo sasha
    malo sasha Newbie
    I checked all options and the most related one was DDI control : DDI to TBH or DDI to DP.
    But still no luck , i think the firmware version is too old and incompatible with the kernel driver ;( I m checking with the support from Eurocom to check if they can help
  5. Meaker@Sager
    DDI to TBH on both for testing.
  6. malo sasha
    malo sasha Newbie
    Hi
    Eurocom support gave me the update utility for the firmware.
    I reflashed the firmware which was 23.0 to 23.0 and on reboot all worked like a charm. I tested various security / misc options and it always works. I guess my firmware was wrongly flashed or in a broken nvram state.
    All good now at least :)
    Papusan and Dennismungai like this.
  7. Meaker@Sager
    Nice, glad it's sorted.
Similar Threads - Eurocom (P750TM1 apple
  1. TurbodTalon
    91
  2. flightsim91
    497
