eRecovery problem
Discussion in 'Acer' started by zero2hundred, Aug 13, 2007.
  1. zero2hundred
    zero2hundred Newbie
    I got a aspire 5584WXMi notebook but it was infected by some kind of virus n
    then i try to reset it to Factory default by using my laptop eRecovery backup CD(not the original CD bcoz Acer didnt provide it to me) but it didn't work it says Restore Failed - reason 0xd000001e n then i try to use my desktop eRecovery backup CD on my laptop.. n it works.. but the thing is.. its doesnt suit my laptop.. =_=" n then i try to restore it again using my laptop eRecovery backup CD again for da second time.. but it still doesnt work.. any Pro technicians here cn help me? :(
  2. IceDragon7
    IceDragon7 Notebook Evangelist
    A little more detail on how it didn't work? like does it not run at all or what?
  3. Knightendo
    Knightendo Notebook Consultant
    The only thing i can think of is to buy a Windows Vista retail disk and then just install the drivers for that notebook. Also does anyone know how to merge the hidden partition with the main driver? i tried several programs yet none have been able to merge them successful
  4. zero2hundred
    zero2hundred Newbie
    Lol I figured it out anyway.. :) just hv to press alt F10 when we see the Acer logo after i boot my laptop.. after dat i just reset it to Factory Default :D
  5. hoggie
    hoggie old boy
    one last thing have you made the recovery dvd's ?
    please read the hand book under "recovery" you may need to do this now.
    all the best hoggie
  6. Ikeago
    Ikeago Newbie
    heya man i have the same problem with the same error message. I got the laptop and wanted xp on it so i wiped the hard drive and installed xp but had to go back with vista so i got the recovery cds from them and when i tried to recover it i got the error message. i tried to do what you did (press alt f10 ) but all i got was a really loud noise then nothing any ideas or help thanks ikeago
  7. andyasselin
    andyasselin Notebook Deity
    be sure once you restore back to oringal to burn you self set recovery dvd just in case :>
