Engineering Major, deciding between GS65, Aero 15x, Blade, Etc.
Discussion in 'What Notebook Should I Buy?' started by jdmcnett, Jul 13, 2018.
  1. jdmcnett
    jdmcnett Newbie
    So basically, I am looking for something that is going to last 3-4 years and still be capable. I have done research on the three in the title, but am open to suggestions. Also, if anyone could help me figure out which reseller to buy it from and with what options that would be appreciated (LM or regular thermal, those kind of things). Thanks!
    1) What is your budget?
    2500$, roughly the equivalent cost of MBP
    2) What size notebook would you prefer? 14-15.6
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen
    The good ol' US of A
    a. Like: MSI, Gigabyte, pretty much any with good rep
    b. Dislike: razer seems bit overpriced
    nope
    Classwork, Excel, word, etc. Gaming. Watching Netflix. CAD, Solidworks
    Yes, will travel frequently around campus.Under 5 lbs
    Yes, CS up to BF, Fallout
    4-5 would be nice so I don't have to charge in class.
    Ok, with not seeing. I have handled a GS65 at Best Buy.
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    standard 1920 x 1080. Don't think 4k is worth the premium
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    matte
    Build Quality and Design
    Something subtle is better, but don't care too much.
    In the next week or two.
    Ideally 3-4 years to get me through school.
    Notebook Components
    512 min, but was looking at maybe 256 versions and adding another ssd
    no
  2. RampantGorilla
    RampantGorilla Notebook Deity
    Reviews of each machine are below:
  3. jdmcnett
    jdmcnett Newbie
    Thanks I will check them out!
  4. 9ac3
    9ac3 Notebook Consultant
  5. 613codyrex
    613codyrex Newbie
    Just to make it slightly more difficult for you (lol) Here’s another laptop to take a look at:
    Asus Zephyrus GX501VI-XS74 laptop.
    At this point, if you can get your hands on one at Best Buy, you can always price match the laptop and then you can warranty the laptop with Best Buy and it will be a peace of mind for you when you drop the money on it.
  6. jdmcnett
    jdmcnett Newbie
    Just purchased GS65 from HIDEvolution!
  7. Spartan@HIDevolution
    Congrats man! They have some of the best build quality out there and by far the best thermal paste application.
    I hope that you got the Thermal Grizzly Conductonaut or if you will be moving around a lot, at least the Fujipoly thermal pads for increased cooling
    jdmcnett likes this.
  8. jdmcnett
    jdmcnett Newbie
    Thanks! Yes I did end up getting the conductonaut with the fujipoly pads, I’m just hoping that their application technique will be good enough to prevent any leakage as I will be using this at college and will be moving it a lot
  9. Spartan@HIDevolution
    They applied nail polish around the CPU/GPU dye on my GT75 Titan to prevent leakage so I am assuming they'd do the same on yours although to be honest, if I was going to move around a lot, a safer bit would be to go with IC Diamond but keep those Fujipoly thermal pads and call it a day.
  10. JRE84
    JRE84 Notebook Deity
    Gs65 is the king of those laptops.... Congrats
Similar Threads - Engineering Major deciding
  1. Bob6636
    2
    620
