enabling bluetooth by default on m860tu/np8660 ?
Discussion in 'Sager and Clevo' started by maennj, Nov 1, 2008.
  1. maennj
    maennj Notebook Enthusiast
    Hi guys
    Is there a way to turn on bluetooth by default so I don't have to turn it on everytime I want to use my bluetooth mouse ?
    The reason am asking this question too, because I have Linux installed and it appears that there is no way to turn on bluetooth on linux (because clevo stupidly made the only to toggle radio is by software, no hard toggle !)
    So if bluetooth is enable by default, I wouldn't have to find a way on how to use hot keys in linux. I tried in BIOS but didn't find anything interesting.
    Regards
  2. theriko
    theriko Ronin
    the function keys should be trapped by the firmware before they get to windows so should work in linux as well. Does fn+f12 not do anything for you? Do any of the other function keys work in linux?
  3. livesoft
    livesoft BUSTED
    Even if the hotkey software is not running, you should be able to turn on bluetooth I think. Does the other Fn keys work?
  4. maennj
    I stand corrected, I tried FN+F12 and checked dmesg logs, it appears bluetooth is being enabled. The problem was from kde blutetooth manager. However, I managed to get it worked by using hcitool and hidd
    Answering your question, some keys worked correctly like LCD and some don't like brightness, sound control doesn't work but when I press FN+F6. kde shows volume level on the screen but it doesn't go up ..
    Regards
  5. Hitman1
    Hitman1 Newbie
    I´ve had the same problem under Vista, is there a way, on startup, to turn on Bluetooth automaticly?
  6. Gixxerdude
    Gixxerdude Notebook Consultant
    I also wonder this, love my bluetooth but do not want to hit fn+f12 every time(god am i lazy)
  7. DanteOmar
    DanteOmar Notebook Guru
    I have an Acer Aspire 6920G with Vista x64 and a MS Bluetooth Notebook Mouse 5000. I have the same issue... and is not solved..... any hint?
  8. Kevin
    Kevin Egregious
    Yeah it would be nice to have the option for it to be automatic at Windows startup.
    Question: are there any Vista equipped notebooks that have auto startup for bluetooth modules?
  9. theriko
    theriko Ronin
    yep, the 5793 does :)
  10. Sadunkal
    Sadunkal Newbie
    I have a bluetooth mouse and all this is pretty annoying to me as you can guess. So is there really no solution to this bluetooth problem? No way to enable it by default?
