Eluktronics MAX series Laptops
Discussion in 'Other Manufacturers' started by B0B, Jan 23, 2020.
  1. B0B
    B0B B.O.A.T.
    So far so good! The MAX-17 turned out really great!
    The MAX-15 is impressive too but definitely hits its GPU thermal throttle limits. An easy tune via Voltage Curve Editor solves this rather easily. However, I was told that Eluktronics will be offering Liquid Metal. I’d like to see how this does on the GPU and not just the CPU :)
    MAX-17 GM7CP0P
    MAX-15 GK5CP7Y
    build6, victorgm, Notsure770 and 4 others like this.
  2. Mr. Fox
    Dang, that's everything the MAG-15 should have been.
    B0B likes this.
  3. B0B
    B0B B.O.A.T.
    Out from Intels bios having 87c limit proper to the GPU is always nice lol.
    Then the software function with the hardware is nicer.
    Top it off with a larger chassis and we’re good to go!
    LM on these with your newer solution could be sweet! Then a fancy bios and Boom! Epicness!
    Mr. Fox likes this.
  4. Mr. Fox
    Glad to see the addition of a numeric keypad. It's unfortunate that the external display options are limited. If it had dual mini-DP output it would be the nicest and best low-cost work/play combo notebook option available on the market.
    The MAG 15 just missed too many basic necessities options for a decent system to qualify as a good option for a business machine (for me). The absence of a numeric keypad and the severely limited external display options instantly disqualified it for my purposes.
    etern4l, xtravbx and B0B like this.
  5. xtravbx
    xtravbx Notebook Evangelist
    Seems like a very solid machine for the money.
    Are all Eluktronics Tongfangs?
    Mr. Fox likes this.
  6. B0B
    B0B B.O.A.T.
    TongFang and Clevo.
    xtravbx and Mr. Fox like this.
  7. BrightSmith
    BrightSmith Notebook Evangelist
    What is the specific number of the MAX-17 Tongfang chassis? Getting confused. Thanks.
    Edit: also, which other resellers are using this chassis?
    Randomisity and Mr. Fox like this.
  8. dieandromeda
    dieandromeda Notebook Enthusiast
    try look at this video
    Randomisity likes this.
  9. BrightSmith
    EDIT: nevermind! I see B0B has updated his post with the chassis numbers
    Much appreciated @B0B
    build6 likes this.
  10. CocoLoco
    CocoLoco Notebook Guru
    A few questions if anyone can help:
    1. Is there a way to redefine keys built in to Eluk Max 17? There is no INSERT key. :(
    2. Can anyone comment about its usefulness on battery? I have Aero 17, and its battery/power profile is totally dysfunctional on battery. No changes I have made have helped.
    3. Does it have annoying audible circuit whine like Aero 17 and most other thin laptops?
    alaskajoel likes this.
