EliteBook 8740w Ultimate Upgrade Guide (mSATA mod, GPU upgrade, cooling and etc)
Discussion in 'HP Business Class Notebooks' started by triturbo, Aug 18, 2015.
  1. azal younnes
    azal younnes Newbie
    pc does not turn on gtx770m
    for the k3100m does not turn on but there is light on the screen
    I think it is necessary to install the driver before inserting the gpu in the pc
    help me please
  2. bassman5066
    bassman5066 Notebook Guru
    No that's not how it works, the driver is installed in the OS and you don't need a driver to see your bios screen or even boot into Windows. Without a driver it will just come up as "Microsoft Basic Display Adapter" in Windows. You either have a bad card (or motherboard) or you may need vBIOS flashed to one compatible to our EliteBooks. If the PC completely won't turn on with the card inserted I'd say you have a major issue with the card or computer.
    Sent from my Nexus 6P using Tapatalk
    triturbo likes this.
  3. azal younnes
    azal younnes Newbie
    how to flash vbios
    please show me
  4. PATRICK NDZENGUE
    PATRICK NDZENGUE Notebook Enthusiast
    I have an elitebook 8560w with a quadro fx 2800m that is mxm 3.0b card. All work fine with temperature too because the highest is 69 degree celcius but i have two problems. The first is that the gpu doesn't reach the 600mhz on core clock. It's only above 340mhz. Memory and shaders too doesn't reach the maximum frequency. The second the brightness that i can't adjust. My specs are:
    i7 2820qm
    6 gb of ram ddr3
    700go hdd
    No dream color screen hd+
    120w charger.
    Please what is wrong ?
  5. PATRICK NDZENGUE
    If i need to flash vbios please give me the file or the link.
  6. azal younnes
    azal younnes Newbie
    how to flash vbios on HP Elitebook 8740w
    i have gtx 770m and quadro k3100m both both of them not working
    help me please
  7. Fungus99
    Fungus99 Notebook Consultant
    Has anyone successfully managed to get a Quadro m5500 working?
  8. triturbo
    As far as I know no one has ever tried and it's pretty rare, not to say unobtainable, GPU to begin with.
  9. cafeogu
    cafeogu Notebook Enthusiast
    Don`t need flash, you need CPU with intel graphics. I am use "non supporting" k1000 in my 8740w with 540m cpu. With 720qm it doesnt work.
  10. Fungus99
    I'm looking in to buy a Quadro m4000m.
    Will I need to flash vbios or will it simply be installing new drivers?
    The stock card is the fx3800.
    Will the including heatsink need be swapped out as well?
    The panel is dc display. Will I still be able to run the m4000m with 10bit colour enabled?
