E6500: How to lock Touchpad
Discussion in 'Dell Latitude, Vostro, and Precision' started by dj_nemo, Nov 14, 2008.
  1. dj_nemo
    dj_nemo Newbie
    Hi friends...
    finally i got a DELL Latitude E6500 :)
    it's not my first laptop but always i have problem with Touchpad when typeing
    is there any way to Lock/Stop using touchpad and Use normal Mouse.
    thanks a lote
  2. booboo12
    booboo12 Notebook Prophet
    Look in the notification area (the far right portion of the taskbar where the clock is) and double click on the small icon that looks like a touchpad. This should open the "Dell Touchpad" control panel.
    In the "Dell Touchpad" window, click on Device Select/Button Settings. Then put a check in the box at the bottom of the window called "Disable touchpad/pointing stick when external USB mouse is present."
    Click OK then close Dell Touchpad. You may see a balloon note stating that the touchpad has been deactivated. That's normal, and will disapper in a couple seconds (you can also just close the balloon note too)
    Ricky :)
  3. afhstingray
    afhstingray Notebook Prophet
    there is also an option called "touch check" enable it and increase its sensitivity. its a software feature to "detect" if its your palm touching the touchpad or if its a finger.
