E6400: CD/DVD drive buzzing noise
Discussion in 'Dell Latitude, Vostro, and Precision' started by akwit, Apr 22, 2009.
  1. akwit
    akwit Notebook Deity
    Yet another problem...:mad:
    When I am burning a cd or dvd, the drive makes a really loud buzzing noise that sounds like its coming from some sort of vibration.
    If I push the drive in and up just a bit while this happens, the vibrations stop and the noise goes away.
    Any idea on how to permanently make it stop?
  2. ZaZ
    Ask for a new one.
  3. Theros123
    Theros123 Web Designer & Developer
    if your unit has this many problem...then I see no reason why to continue using it. Return it or get a replacement. Might as well get one that does not have ANY issues.
  4. valbaca
    valbaca Notebook Guru
    Mine did this once when I first got it.
    Try removing it and putting it back in. Also make sure your disc is set correctly.
    If this doesn't help, I agree with Theros123 and ZaZ.
  5. John Ratsey
    Make sure you have got the disc pushed down firmly in the tray. I have the habit of spinning the disc with my fingers before closing the drawer so I can see if it is not sitting evenly.
    If you are still getting a lot of noise after removal / replacement of the burner and with several different discs then it is time to ask Dell for a replacement.
    John
