E4600: is the audio quality from the DisplayPort(HDMI) same as from the headphones?
Discussion in 'Dell Latitude, Vostro, and Precision' started by tracerit, May 15, 2009.
  1. tracerit
    tracerit Notebook Consultant
    I'd like to load a few 720p movies onto my E4600 and hooking it up to my LCD TV to watch movies. Thing is that when I connect my 2.1 speakers to the laptop through the headphone port, the audio isn't very good. I'm wondering if when I use the DisplayPort (will be using a DP->HDMI cable/adpater) will thet audio quality be the same.
  2. litkaj
    litkaj Notebook Consultant
    Audio from the headphone port will be analog converted by the system's sound card (and subject to volume controls on the system as well as your speaker system). Audio from an HDMI/DisplayPort connection will be digital and converted to analog by your receiver. In short, don't use the headphone port unless you've got to.
  3. tracerit
    what if i don't use a receiver? i''ll just be connecting the laptop straight to the LCD TV with that DisplayPort->HDMI cable.
  4. litkaj
    Then your TV will be doing the digital to analog conversion and, depending on the type of data sent (AC3, for example), possibly the decoding and downmixing as well.
    EDIT: If the TV allows volume control of the signal it outputs, as well as your speaker system, then you're not really any better off than sending audio straight from the notebook unless you're getting interference from the HD, DVD drive, etc. when using the notebook's headphone ports.
