DVD drive read/write problem please help!!!!!
Discussion in 'Dell' started by Reaper21, Jul 24, 2006.
  1. Reaper21
    Reaper21 Notebook Enthusiast
    Hey guys,
    I'm having a really annoying problem, basically my DVD-RW drive in my inspiron 9400 (e1705) has stopped working properly.
    Although it does work (burn dvd's and read cd's etc.) its running really really really slowly. It reads at about 500 kb/s when reading a dvd and takes about 2 hours to burn a 4.8gb dvd, this is rediculous i can't do anything with it cause it takes years to get anything done. Has anyone had this problem before? if so how did you fix it? Can someone suggest a solution?
    P.s i've run the dell diagnostics and they all say its fine (even though it took ten years to finish), i've also tried the nero speed test (which failed). If anyone can think of something else i can use to diagnose this better i would be very appreciative, thanks
  2. Hiker
    Hiker Notebook Deity
    You definately seem to have a problem there.
    Although I've only copied and burned a couple of DVD's since I got my laptop, they took about 10 and 14 minutes respectively with the Pioneer hardware and Sonic software.
  3. Reaper21
    i should have mentioned i've got the sony dvd-rw.
    Yeah its wierd because it only started happening about two days ago
  4. ScifiMike12
    ScifiMike12 Drinking the good stuff
    Check to see if there is a firmware update for your DVD writer. Or perhaps, it could be a heat issue.
  5. Blackzombie
    Blackzombie Newbie
    I have the exact same problem, with a DELL E1505 please Help me I just tried to burn an Audio CD it took over 30 minutes to complete. I checked the DMA properties, and this is what I've Found
    There are two IDE Controlers
    Primary IDE Controller
    Device 0:
    Set to Automatic DMA when available
    Currently Active: Ultra DMA Activated
    Device 1:
    Currently Active: Not Available
    Secondary IDE Controller
    Device 0:
    Currently Active: PIO Mode Activated
    Device 1:
    The only option besides "DMA when available" its PIO mode only so how can i activate DMA on device 0 of secondary IDE Controller?
    Please Help
  6. PhoenixFx
    PhoenixFx Notebook Virtuoso
    Uninstall the Secondary IDE channel (Right click > uninstall) from the device manager, then refresh or restart the PC. That should put it back to DMA. Your slow burns and reads are definitely due to PIO mode.
  7. Blackzombie
    Blackzombie Newbie
    Thanks that worked Just Fine! :D
