dvd burner for cf-30 mk iii?
Discussion in 'Panasonic' started by Stewboy, Mar 14, 2015.
  1. Stewboy
    Stewboy Notebook Consultant
    Hello gents,
    Can anyone recommend a dvd-rw/cd-rw drive for a cf30? I was under the impression that the matshita ujda 760 would burn dvds, but it only reads them. Thanks for the help.
  2. toughasnails
    I am at work now so can't get to my laptop but there is a couple out there that works great....one is a slot load that works very good and is used my one of our long term members. He puts them in almost all the ones he sells
  3. Stewboy
    Thanks Blair--whenever you can get to it. Thanks. Anyone else?
  4. Shawn
    I have an extra Sony.....Let me throw it in a caddy and verify it..
  5. Shawn
    I have a Sony that works fine..Verified that it boots also..Not all of any model or brand will boot.
    I just checked in my CF52...
    I'll send you a Private message.
  6. I58SR
    I58SR Notebook Consultant
    The OEM model # that burns CD and DVDs is CF-VDM302AU. Mine shows up in the hardware profile as Matshita DVD-RAM UJ-841S
    -Nick
    UNCNDL1 likes this.
  7. Shawn
    I am shipping one tomorrow...
    I said this in a private message but it's worth repeating here.
    Just because A toughbook comes with XYZ model optical drive, does not mean that you can buy the same model from ebay and it will work.
    XYZ drives in Toughbooks are usually set to Master....Many other laptop companies use Cable Select.
    A Toughbook "may" recognize the drive in windoze, but I guarantee you it won't boot from it.
    At 1am the night before the big project is due, when you must restore your CF52 using the DVD's, this is a problem....I know from experience...
