DV7 isn't charging battery...
Discussion in 'HP' started by Jeremy14, Oct 5, 2008.
  1. Jeremy14
    Jeremy14 Notebook Evangelist
    my notebook isn't charging my battery.. it was on 10% ( i was gaming so noticed it too late it was so low..) i plug it in the fan goes mad spinning... i hover the mouse on the icon it says, on A/C, Batter isn't charging...
    What the hell happened?
  2. bulik
    bulik Notebook Consultant
    have you already checked your battery using the hp battery health check tool? or it could be that the charger is not working properly anymore
  3. Jeremy14
    yes and it's good, the odd thing is it's charged now, for 96% but it just stays and says battery osnt charging...
    ooh well.. maybe it's just vista:)
  4. Infamous22
    Infamous22 Notebook Deity
    Do the following:
    Turn off the notebook. Unplug the A/C cord and disconnect the battery. Hold down the power button on the laptop for 8 seconds. Reconnect the battery and plug in the cord. Everything will work. Repeat as needed.
  5. Jeremy14
    uuh.. hold don power butten and at the same time recconect the battery or are al just single steps??
  6. Infamous22
    Hold down the power button after everything is disconnected.
  7. Jeremy14
    oke:) it worked:)
  8. BBGus
    BBGus Notebook Evangelist
    Just so you know Jeremy, Infamous essentially had you reset the system including the battery sensor/indicators.
    BBGus
  9. Jeremy14
    okee. that's why i had to restore my whole computer:p
  10. deeastman
    deeastman Notebook Deity
    No, reseting the computer in that manner would NOT cause you to have to restore the data on your whole computer, if that is what you meant. If you had to restore the data on your whole computer it was because of some other issue.
