dv6-6195ca Wireless Issues?
Discussion in 'HP' started by Coolio10, Sep 9, 2011.
  1. Coolio10
    Coolio10 Notebook Enthusiast
    I recently purchased a 6195ca and it seemed to suffer from wireless card issues after a week or so of ownership. The wireless was extremely slow on the default setting of wireless n enabled. I tried disabling the wireless n and it seemed to solve the issue, but why would i buy a wireless n router, and not take advantage of it?
    So i emailed HP Support and they recommended i reinstall the drivers which did not solve the issue. They then recommended i install a BIOS update, which was previously installed automatically by the support assistant software. Reinstalling the BIOS did solve the issue, but now i don't understand how.
    Why did reinstalling a previously installed BIOS fix the issue. And even if there is no explanation, will this become a common occurrence of reinstalling the BIOS every time the wireless card plays up? I always thought the BIOS was permanent and did not deteriorate over time and suffer from issues.
  2. criskoe
    criskoe Notebook Guru
    Hey i am having the exact same issue... http://forum.notebookreview.com/net...-speeds-new-broadband-cisco-modem-router.html
    I as well have the dv6-6195ca and wireless problems.... The only way i was able to fix it was to either use wireless G or dissable bluetooth completely on the wifi/bluetooth card... Anyways Please tell me what bios version did you reinstall? and what speeds are you getting over the wifi now that it seems to be working?
  3. Coolio10
    Here is the entire email i received.
  4. neothe0ne
    neothe0ne Notebook Consultant
    Tell HP they need to remove the "WLAN whitelist" from the BIOS so we can install our own, competent wireless cards. The Intel WiFi Link 1000 is terrible, as is the 1030.
  5. criskoe
  6. neothe0ne
    Ask them to send you a Centrino 6230 for testing................
    (probably won't end well because the BIOS might have it blocked. but point at the Service Manual then.)
  7. criskoe
    Anyone with a DV6- with a intel wireless 1030 N w/Built in Bluetooth?,
    What speeds are you able to achieve over wireless N while using the bluetooth at the same time (like a bluetooth mouse)????
    For some reason it seems i can use the wireless N and Bluetooth connection at the same time, But only on a wifi modem that puts out a 25mb connection or lower.
    But when i try to connect to my new 50mb broadband connection I just got at home (DPC3825 Cisco wifi modem) through wireless N and have Bluetooth on, it craps out to less than 1mbps and sometimes completely freezes and gives 0. If i disable the built in Bluetooth on the Intel 1030 N in the device manager it works most of the time and im able to get a 48.5mbps dl but every now and then it seems it messes up and brings a download or upload to turtle speeds or even cuts right out untill i reset the connection.
    Using wireless G seems to be the only setting that gives me a constant stable speed without any problems, but is only around 17mbps on my 50mb connection. and moving files around on wireless G network sucks compaired to N... :( As well I want to be able to use my Razer orochi Bluetooth Mouse.... :(
    Ive tryed every different setting as well as everything posted in that email.. Even put in a new 1030 N that HP sent me and all is configured correctly, yet no go...... A HP rep said that the Intel Wireless 1030 N card cant handle using its built in Bluetooth and a high broadband connection (anything over about 25mbps) at the same time. He said the little 2in1 (Bluetooth/Wifi) is just not good enough.
    I was hoping that someone out there could confirm this or prove that it actually can on this DV6.. My model is the DV6-6195CA
    Lastly what is the best way to request the whitelist be removed?
  8. neothe0ne
    The thing is, I think you're the first person who's ever reported having the Intel WiFi Link 1030. Everyone who custom-ordered in the US got the WiFi Link 1000, even if they selected Bluetooth (it's a separate chip).
    What country are you in, when did you buy this laptop, and was it quick-ship or custom order? Do you also happen to know what BIOS version you're running?
    Also, can you go to Device Manager (Control Panel > System and Security > System > Device Manager), then choose > Network adapters > Intel 1030, then right-click > properties > Details tab, and select "Hardware Ids" in the dropdown menu. Can you post what the Ids are? They should start with "PCI\VEN_...."
  9. criskoe
    Hmmm interesting...
    Im in canada and i got it at a local best buy about a month ago.. I think its been available here for about 2 months tho.. Only at best buy. HP Canada doesnt even have them available to Canadians yet..
    DV6-6196CA | i7-2630QM (2.0 GHz) | 2GB GDDR5 Radeon(TM) HD 6770M | 8GB DDR3 System Memory | 750GB Hard Drive | 15.6" diagonal Full HD HP Anti-glare LED Display (1920 x 1080) | Intel Wireless-N 1030
    Intel Centrino Wireless-N 1030 ----->HP Part Number 631956-001
    PCI\VEN_8086&DEV_008B&SUBSYS_53158086&REV_34
    PCI\VEN_8086&DEV_008B&CC_028000
    Thats whats under the HArdware Ids.
  10. Coolio10
    Having problems again now. It seems to fluctuate a lot in speed. Sometimes it loads pages instantly, other times it takes several minutes. There does seem to be some sort of interference. Just yesterday i was getting 18mbps, and now im getting 1mbps or less again. I will try get HP to send me a replacement card. Disabling bluetooth does seem to help a bit, but there is obviously issues with the card if it cannot be enabled.
