DV6 6170sl screen upgrade, HD to FHD display (some clarification and advice))
Discussion in 'HP' started by Dedeee, Aug 4, 2019.
  1. Dedeee
    Dedeee Notebook Enthusiast
    Hi guys, I wanted to breathe some new life into my old and faithful pc, a 2011 hp dv6 6170SL :)
    I just replaced the hdd with an ssd and I was looking forward to replace the current HD screen with a FHD panel. Needless to say I am a bit confused reguarding original parts, compatible parts, and whether they would be supported by the motherboard/BIOS of my pc model.
    I was wondering if somebody with clearer ideas could give me some much needed advice and guidance
    This is the maintenance guide of my PC
    http://h10032.www1.hp.com/ctg/Manual/c02842252
    The new parts to should be
    Display 653378-001
    FHD Cable 656805-001
    All the specs in case they're useful
    HP - Pavilion dv6-6170sl Metal Steel Gray
    Intel Core i7-2630QM 2.00-GHz (SC turbo up to 2.90-GHz) processor (6.0-MB L3 cache, quad core, 45 W)
    RAM 8192MB (2 x 4096MBD DR3)
    Hard Disk 500GB (7200RPM)
    ATI RADEON HD6770 (2GB GDDR5)
    Display 15.6" HD LED BV (1366x768)
    DVD Super Multi DL, Wifi b/g/n, LAN Gigabit Ethernet, Intel Wireless Display
    2 x USB 3.0 + 2 x USB 2.0, HDMI, digital media card reader, Webcam HD HP TrueVision, TouchPad with Multi-Touch Support,
    BEATS AUDIO, HP CoolSense, Fingerprint Reader, HP SimplePass
    what I would need to buy:
    screen
    https://www.laptopscreen.com/Italian/model/HP-Compaq/653378-001/
    cable
    https://it.aliexpress.com/item/32805340369.html
    or
    https://www.ebay.it/itm/Cavo-Flat-v...588717?hash=item443583886d:g:ZLcAAOSwwIZXTBok
    I guess the most important thing is... does the motherboard and bios of my PC support a FHD Panel? (it would seem so from the maintenance guide, can anybody more knowledgeable than me confirm? :D)
    And for the same value, is there a better quality screen that isn't the display of HP Part Number 653378-001? I read about LG LP156WF1 or AUO B156HW0x (from the post http://forum.notebookreview.com/threads/hp-dv6t-display-replacement.610177/ )
    Thank you, I know the laptop is a bit old but any help is appreciated :)
    and feel free to say if the upgrade is worth it or not
