dragon center does not read my gpu temp
Discussion in 'MSI' started by Overste, May 12, 2017.
  1. Overste
    Overste Newbie
    Hello sir / madam,
    I have a problem with my MSI. I had to download visual studio for school. Because of that dragon center does not see my GPU temp anymore. Sometimes you see for a fraction of a second the GPU-temp. When you see the GPU-temp, the GPU fans also blow fans for a fraction of a second. As a result, the GPU is not optimally cooled.
    I have removed dragon center and installed. Visual basic removes and dragon center re-installed.
    I've installed windows 10 again. Nothing did worked.
    I hope that you have an idea because I don't know it anymore.
    Thank you for your time.
  2. skydiverjeff
    skydiverjeff Newbie
    If you are using a dual video card setup and the graphics are set to auto select you will not see graphic card info in Dragon Center until whatever application uses the add on video card.
    No info displayed for built in video.
    Go into video settings, select as primary additional video card and info will be shown in Dragon Center.
