Downgrading GPU, Need Advice
Discussion in 'Desktop Hardware' started by Yuna.Fire, Aug 4, 2017.
  1. Yuna.Fire
    Yuna.Fire Notebook Consultant
    Due to financial woes I'll likely need to sell my 4GB GTX 970. I certainly don't want to, but as I haven't been gaming at all since purchasing a PS4, it's really a no-brainer.
    These days I primarily use the pc for streaming 1080p video (youtube, plex, hbo now) and occasionally some light photoshop. I need a GPU that's good enough for all that. The cheaper, the better. Whatever I sell the 970 for, I'll need to put mostly towards bills. My mobo is Asus p8p67 with an Intel i5-2500k 3.3GHz cpu, so, unfortunately, integrated graphics is not an option.
    Any help at all is definitely appreciated. Thank you!
  2. namaiki
    namaiki "basically rocks" Super Moderator
    Pretty much any GPU can do 1080p GPU. What are the requirements for Photoshop? Does that need to be GPU accelerated?
  3. Yuna.Fire
    Just checked and it primarily uses memory/cpu. There's an option for gpu acceleration, but that's only for 3d things... which I never use anyway.
  4. Raidriar
    Raidriar Notebook Prophet
    You should be able to get away with using the iGPU....my intel HD 3000 handles streaming and 1080P content just fine.
    TBoneSan likes this.
