Downgrade from Vista 64 to XP Pro
Discussion in 'Lenovo' started by Runner, Jun 7, 2009.
  1. Runner
    Runner Notebook Enthusiast
    I ordered my T400 w/ Vista 64 but am now thinking that I should have started w/ XP Pro. I did order the XP recovery DVD with my system. Will I need to reformat the hard drive to switch to XP?
  2. Renee
    Renee Notebook Virtuoso
    No, no, no you made the right decision with vista originally
  3. Runner
    OK, that reassures me. But, am I going to have any problems using remote desktop from the Vista 64 to an XP Pro computer on the same network?
  4. jonlumpkin
    jonlumpkin NBR Transmogrifier
    Not really a problem but you will have to check a box that says "allow connections to computers running an earlier version ..." as XP doesn't have some Remote security feature of Vista/7. However, if you check the box and save settings, you shouldn't have any trouble.
  5. Runner
    OK, Thanks! I should have mentioned XP Pro 32, is the answer the same? I plan on connecting to the older desktop from the T400.
  6. bsodder
    bsodder Notebook Evangelist
    32 v 64 bit makes no difference with RDP...
  7. Renee
    I'd second what john says. There was no xp 64-period so it was all xp-32.
  8. jonlumpkin
    Not true. Windows XP Pro 64-Bit. However, the 64-bit version was rare and I don't recommend it because driver support is awful.
  9. Thaenatos
    Thaenatos Zero Cool
    Ditto. Oh and OP stick with vista, it is better all around then XP.
  10. MastahRiz
    MastahRiz Notebook Evangelist
    Vista is the way to go. And you could save yourself all this trouble and worrying and just use a program called Team Viewer, which is free and sets up a perfect remote desktop connection every time, regardless of which Windows is installed on either end.
