dose Inspiron 6400 duo cor2 make High Pitched Noise ?
Discussion in 'Dell' started by RO911, Jul 31, 2007.
  1. RO911
    RO911 Notebook Guru
    dose Inspiron 6400 duo cor2 make High Pitched Noise form CPU ?
  2. Nedediah
    Nedediah Notebook Consultant
    It shouldn't. If it does then the most likely problem is a bad fan.
  3. hehe299792458
    hehe299792458 Notebook Deity
    Actually, Core 2 CPUs are known to make high-pitched noise. I forgot was exactly was the cause, but replacing the motherboard usually helps. I don't know if this issue had been resolved in SR
  4. Nedediah
    Now that you've said it that does ring a bell, but I thought it was just for the headphone noise issue.
    Anyway, it's hard to tell if the OP is getting a mechanical noise or a something from his systems' audio output...
  5. RO911
    RO911 Notebook Guru
  6. mtor
    mtor Notebook Deity
    No laptop should make any high pitch noise
  7. HDTV4me
    HDTV4me Notebook Consultant
    Mine 6400 with C2D doesn't make any noise, even system fan is practically silent
