doom 3 ultra settings and 6800 go
Discussion in 'Gaming (Software and Graphics Cards)' started by farhan007, Jun 27, 2005.
  1. farhan007
    farhan007 Notebook Enthusiast
    hey, im buying a i9300 with a 256mb 6800 go.... ive looked around for benchmarks of doom 3 with that vid card, but all they have is high settings.....
    im just curious, how well doesn doom 3 run on ultra settings with the 6800 for those of you you have tried it
  2. LuckMC11
    LuckMC11 Computer Extraoirdinaire NBR Reviewer
    i found out that sum ppl dont c any performance diff. b/w high and ultra..so they jus keep it on high 2 increase their battery life..and that sum ppl c hugh diff. b/w the high and ultra..and onli use the ultra wen plugged into an AC adapter plug
  3. farhan007
    im going to be plugged in most of the time...im just curious what the average fps is...
  4. ASZ993
    ASZ993 Notebook Enthusiast
    Actually, Ultra Quality was designed for 512 MB video cards. So, if you have more than 1GB of RAM, then you're set. However, there is no visible difference between High and Ultra.
    BTW, what resolution are you trying to run Doom 3 at?
