Does the fans work when you browse on inspiron 7577
Discussion in 'Dell' started by AlexanderKim, Sep 20, 2018.
  1. AlexanderKim
    AlexanderKim Notebook Guru
    I just noticed, when i just browsing/coding (vscode), my fans are spinning slightly, wont they be completely off during such tasks?
  2. Maleko48
    Maleko48 Notebook Evangelist
    Depends how you have your machine setup.
  3. DoctorRzepa
    DoctorRzepa Notebook Guru
    Dissbling turbo in bios helps a lot
    Maleko48 likes this.
  4. AlexanderKim
    Its by default
  5. Maleko48
    Depends where you set your battery slider and if you have active or passive cooling options selected in your Windows power options.
  6. AlexanderKim
    Maximum performance and Active cooling set.
  7. Vasudev
    Vscode does that on my PC as well, I think it uses GPU too much for UI to get smooth and slick.
  8. AlexanderKim
    I have 3 virtual desktops opened, with VSCode / Postman at fullscreen, i also notice that windows are getting slower after 1 week without reboots, switching between desktops are becoming painly slow. Is there a way to clean out memory without reboot?
  9. Vasudev
    VDM in windows does consume more memory and you can try RAMMap from sysinternals suite to clear RAM. Reboot is always good though.
  10. Maleko48
    I use BitSum Process Lasso to keep my system running nice. It seems to do a good job. It has memory reclaiming functions built into it that are good for heavy users.
