Does resolution or hz make biggest impact on battery life
Discussion in 'What Notebook Should I Buy?' started by Martlin, May 18, 2020.
  1. Martlin
    Martlin Newbie
    Hello! I am planning on buying the new Asus G14 laptop. I am choosing between the 60hz 2440x1440 version or the 120hz 1920x1080 version. My question is, if the rest of the specs are the same, will the higher resoluttion or the higher monitor hz affect battery life the most?
  2. JRE84
    JRE84 Notebook Deity
    its and equal split...id say 60hz 1440p will net you better battery life over 120hz.
    as for which to choose thats very hard to answer as I prefer higher resolutions and many prefer smoother gaming..very tough indeed....go for the feature you favor the most
