Does HDMI output sound?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by chesieofdarock, May 5, 2008.
  1. chesieofdarock
    chesieofdarock Notebook Deity
    This is probably a dumb question, but does HDMI output sound aswell as video? I always thought HDMI only outputted video and you still needed audio cables. Whats the answer?
  2. jin07
    jin07 Notebook Deity NBR Reviewer
    Yes, it can output sound as well. I think HDMI is classified as a digital audio/video connector.
  3. Amol
    Amol APH! NBR Reviewer
    HDMI is an acronym for “High-Definition Multi-Media Interface™,” which means that both audio and video are included [the word "multi-media" should be sufficient hint].
  4. Ayle
    Ayle Trailblazer
    But the presence of sound will depends of the device outputting through it capabilities.
  5. flipfire
    flipfire Moderately Boss
    HDMI can play both high quality digital video/audio. Most notebooks support digial audio
  6. ViciousXUSMC
    ViciousXUSMC Master Viking NBR Reviewer
    The HDMI interface indeed carries digital sound, its basically the combination of a DVI and a Optical Digital sound output into one interface. However your device in question can only have one or the other actually hooked up to and using the interface.
  7. deputy963
    deputy963 Notebook Evangelist
    HDMI, in the broad sense, CAN do digital video resolutions up to 1080p as well as 5.1 digital audio. Now, depending on your devices you may not have these capabilities. Most laptops with HDMI do not output audio. Many devices (Xbox360, Motorola cable boxes, etc) only output 2 channel audio over HDMI, requiring an optical or coaxial cable if you plan to use 5.1 audio.
    So the best answer to your question is read specs for anything you wish to purchase and ask questions before you buy.
  8. ViciousXUSMC
    Most laptops do indeed have audio on the hdmi, but most people do not know how to enable it! you have to manually turn on digital output from your audio control panel in most cases, it is not just plug and play.
  9. ms500
    ms500 Notebook Consultant
    HDMI usually carries digital audio in the S/PDIF format.
  10. TheGreatGrapeApe
    TheGreatGrapeApe Notebook Evangelist
    No S/PDIF is a different format, and more limited in both bandwidth and usually signal format type. HDMI now carries a multitude of formats both compressed and uncompressed, and as a connection type is outside of the S/PDIF spec.
    This may help people;
    http://www.hdmi.com/learningcenter/faq.aspx
    HDMI carries audio and video (although not everything supplies or receives both), DVI can carry Audio in it's additional/spare bandwidth, but it's limited to the extra bandiwdth available in the unused data pins, Display port has optional audio support, which will likely mature like HDMI over time.
