Does Asus Duo Zephyrus handle well 150W vbios flash?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by AndresHdz, Jul 31, 2021.
Tags:
  1. AndresHdz
    AndresHdz Notebook Guru
    I have seen in forums that it is possible to flash a ge76 vbios into the zephyrus duo (3080 115W), which I am considering buying , and that 15% performance increase looks juicy. But I would not want to do anything that the laptop cooling, motherboard and VRMs do not support.
    Considering the flash is done correctly will the Zephyrus Duo handle the 150W okay?
    I do somewhat long gaming sessions and 3D Work.
    Thanks in advance
  2. tilleroftheearth
    I don't think it is a 15% increase... If I'm correct, not worth it since you don't want to risk the entire platform you have that now works.
    AndresHdz likes this.
  3. AndresHdz
    Not even 15%? I would have expected more from a 35W difference...
