Does anyone have the vbios of Eluktronics MAX 2060? 115w TDP?
Discussion in 'Gaming (Software and Graphics Cards)' started by ScarletBlack, Jan 23, 2020.
  1. hertzian56
    hertzian56 Notebook Evangelist
    This is all pretty confusing which versions are which, I'm pretty sure my version is the refresh but how do you know the version of that you have 80-90-115? Is it the boost? I've seen a max of 1860Mhz for the gpu in game but on gpuz it's the 1005/1350 which is below the 1560 boost on techpowerup.
    https://www.techpowerup.com/gpu-specs/geforce-rtx-2060-mobile-refresh.c3567
    Edit: NVM, mine looks to be the max-q refresh 115w version from the specs, very confusing naming.
    https://videocardz.net/nvidia-geforce-rtx-2060-mobile-refresh-max-q
  2. yrekabakery
    yrekabakery Notebook Virtuoso
    Check sustained GPU Power in HWINFO while the GPU is under load.
    GPU-Z sensors tab will also show total board power.
  3. hertzian56
    Yeah while playing cp77 it got up to 95w so it's the middle option. Guess the full 115w is for higher performance or larger laptops.
  4. conker_ts
    conker_ts Notebook Enthusiast
    I'll just join this thread so I can keep track of it.
    So I got a XMG Core 15 (Tongfang GK5NR0O), which is supposed to boost up to 110W.
    (Has 2 mDP and stuff ...)
    But currently I'm talking to support, why mine is stuck at 90w, despite me enabling the overboost/ turbo mode which should enable the 2060 to use 110W.
    Quite annoying, but whatever, I hope they manage to solve it ...
    So if it finally works in future, and there is a way for me to dump the bios and you guys want it, then just tell me how to do it ;)
  5. xLima
    xLima Notebook Evangelist
    GPU-Z Lets your export your vbios, it's a little arrow symbol on the right hand side of the GUI.
    Sent from my BLA-L09 using Tapatalk
  6. hertzian56
