DIY Project Valerie - Triple Screen Laptop (COMPLETE)
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by TheUberMedic, Feb 1, 2020.
  1. TheUberMedic
    TheUberMedic Notebook Evangelist
    Wait there's both an LVDS and eDP connector on the main board? I'm not too sure how it'll handle both being connected. I'm using external controller boards to control my boards.
    As for how you should make it, I originally wanted to do a sliding design but it'd make it much more thicker than I wanted so I went with this design as it's much easier to do.
  2. Mastermind5200
    At the same time?
  3. TheQuentincc
    TheQuentincc Notebook Evangelist
    yes
    I just needed to manually enable the internal graphics with nvram editing.
    moral hazard likes this.
  4. Mastermind5200
    Waiting on that thread....
  5. TheUberMedic
    Holy crap that's cool! Wish my laptop had more internal display connectors. Wouldn't need these external circuit boards and power supply.
    Do eDP splitters exist? Something like an MST hub but using eDP connectors.
  6. Mastermind5200
    In theory, you could convert eDP to DP, then grab a MST hub, then convert it all back again. Thats a lot of work, but then again you've gone this far
  7. TheUberMedic
    Booooo Im practically already doing that. I meant taking the eDP connector on my laptop motherboard and making act like 3 eDP connectors so I could just wire all screens directly to my laptop. No need for external batteries or display cables.
  8. TheUberMedic
    UPDATE:
    The final prints are done!
    Unfortunately, I broke the panels again so I have to order more. Even more sad times is that this virus has make panel prices skyrocket. Before I got each panel at about £50 and now they're around £100 at the lowest and I've seen some at £200 :|
  9. TheQuentincc
    everything is 3D printed ? do the hinge seems solid enough ?
  10. TheUberMedic
    Very. And if they ever break, I can just use a stronger material to print them with
