DIY eGPU experiences
Discussion in 'e-GPU (External Graphics) Discussion' started by master blaster, Sep 18, 2009.
  1. mal3x
    mal3x Notebook Enthusiast
    First post, FAQ #5
  2. nlooije
    nlooije Notebook Guru
    Hi, i have two questions:
    i am able to boot into w7 without any errors on the 460 GTX only if i disable my 8600M GT drivers first...
    1. is there some way to get both drivers working simultaneously because without the internal drivers the internal gpu becomes very hot.
    2. How do i force the 460 GTX to an external screen when it shows no errors. using the shortcut for the external VGA does not seem to work and through the screen resolution screen also nothing can be set. If i load NVidia control panel it says no display is connected to an nvidia display (possibly because i have disabled the internal drivers)
    thanx in advance,
    nlooije
  3. Mayklic
    Mayklic Notebook Enthusiast
    Seems some people have the same problem with windows seven. For the vidock to work the internal gpu has to be turned off.
    There seems to be another case. Other people seem to hot plug the device and under the device manager both gpu runs properly with the only thing that vidock is not giving any output. this allows display setting to direct desktop through the vidock port.
    If you windows is not detecting vidock while on internal gnu, try put windows in sleep, turn on vidock without ec or mpcie plugged, then plug the EEC or mpcie. Hit button to wake the pc. Wait couple of minutes for windows detect vidock.
  4. nlooije
    thx for the reply, hotplugging mPCIE gives me a code 43 error...
    I have the Delay disabled, sleep w7, power Vidock, resume, go to device manager and scan for pnp devices, laptop screen flashes black for a couple of seconds, 460 gtx shows up in device manager but with code 43.
    do i have to wait till device manager finds the 460 gtx itself?
  5. Khenglish
    Khenglish Notebook Evangelist
    I'm trying to remember back when I installed my 460 gtx drivers for the first time. I have an internal 9600m gt. The problem you are having is that only 1 Nvidia driver can be run at a time, and this driver must run both cards for both to work correctly. I might not remember this right, but I think I uninstalled the 9600m driver, then installed a regular Nvidia driver and everything worked fine. If you end up rebooting after uninstalling the driver, make sure you immediately kill the auto driver install in the task manager. Windows will mess up everything. I do remember doing that, but I don't know if the reboot was necessary.
    After you get 1 driver working properly you can update the driver normally without having to worry about anything.
    To answer your second question, yes you do need the driver running in order to use the external monitor. If I disable my internal card, the external 460 will work fine unless I reboot with the internal card disabled. On reboot, the Nvidia driver will not start and I can only see the internal LCD. The 460 will still be listed as detected and running in the device manager, but i can't do anything with it.
    Also there is absolutely no reason to hotplug the 460 if there are not resource issues on boot. Save yourself the effort and just boot with it.
    Getting 2 Nvidia cards working correctly seems to be a common problem. Below I have summarized the key idea:
    ONE DRIVER GOOD, 2 DRIVER BAD
  6. sleepylilazn
    sleepylilazn Newbie
    hi, i was wondering if my laptop can run this sort of setup with a 470
    if i just follow the how to would i be fine?
    i have a dell studio 1555 laptop with a expresscard 34 slot
    cpu - p8600 at 2.40ghz
    ram - 4gb
    graphics - ati mobility hd 4500/5100
  7. User Retired 2
    Request: C2D Dell Latitude owners with 4GB issues - try a T4xxx or T6xxx CPU instead
    As noted here, these systems have TOLUD set to 3.5GB and do not allow 36-bit PCI compaction. The same issue occuring on another MSI system I've been PMed about.
    Now the 36-bit PCI IGP or external gpu compaction that I've witnessed does work was on Inspiron 1440 + Studio 15 with a T6xxx 'budget' penryn CPU. I have otherwise been unable to get 36-bit to work on a P8xxx or L9400 'premium' Penryn. Difference being the 'premium' VT-x, TXT, SLFM, IDA, Vpro features + is running 1066Mhz FSB.
    So if you have one of these Latitude systems AND have a T42xx or T6xxx 800Mhz FSB Penryn lying around AND are willing to swap it in, that would help identify if something about the CPU itself is causing 36-bit PCI relocation to fail. No amount of changing "nolowmem", "pae", DET in the BCD has helped.
  8. skylineboi
    skylineboi Notebook Enthusiast
    Where would Install the pm3n for the x2link? do I have to open all the screws on the back of my laptop to find it or is it in a little section where there are some screws for that particualr part?
  9. Khenglish
    varies from laptop to laptop. Some have an easy to access compartment, others require work.
  10. nlooije
    Lol thx for the summary :p
    I have gone ahead and tried what you suggested. The result is still a code 43 error upon boot. I have tried booting normally, booting through the setup with pci compaction, booting with VD off and hotplugging... all give code 43.
    what i have done since the previous post:
    1. Install w7 64bit which allowed me to use my other 2gb Ram module as well as use the drivers + modified inf file supplied by nando4 a couple of posts ago. This was done in the hope it would prevent the code 43 error.
    2. I uninstalled the 8600m gt drivers and installed the new drivers for both cards as you suggested in your previous post. Unfortunatly, i am not able to stop w7 from installing standard VGA drivers upon boot (it goes too quick), but applying the new drivers afterwards leads to the 8600m gt and 460 gtx showing up in the device manager. See picture below. might this be a problem?
    http://img718.imageshack.us/img718/4613/devicemanager.png
    any other ideas on what i am doing wrong?
    nlooije
