DIY: Adding SSD or HDD storage using an optical bay caddy
Discussion in 'Hardware Components and Aftermarket Upgrades' started by User Retired 2, Jun 9, 2009.
  1. pengy_666
    pengy_666 Notebook Evangelist
    I need the frontplate for current drive as I will be putting it into a external caddy,
    The HDD bay I have is second hand hence having an incorrect fascia.
  2. messwitme
    messwitme Newbie
    Hey guys, so I'm waiting for ssd and hd prices to go down... any ideas when?
    And when they do go down, my laptop is a sager np5160. After looking around, will any of the 12.7 mm caddies fit?
    Thanks
  3. dr.pratik
    dr.pratik Notebook Evangelist
    HDD will fall by 6-8 months.
    SSD no idea.
  4. supirio
    supirio Notebook Enthusiast
    If you monitor slickdeals.net for 'SSD' there are still decent deals to be had now and then from newegg and the like, for instance the Intel 320 160gb was just $165 after mail in rebate.
  5. krizzz
    krizzz Notebook Enthusiast
    yeah and i jumped on a corsair force gt 120gb for 150 after rebate deal.
    thats affordable and well worth the money
  6. DesZac
    DesZac Notebook Enthusiast
    Does anyone know if a Gateway m285-e has a compatible Hard drive caddy?
    all of these list like HP and stuff but I don't see any for Gateway...
  7. DesZac
    Does anyone know?
  8. dr.pratik
    Take out your DVD drive.
    Measure the height of drive.
    Its the size for your caddy.
  9. timohour
    timohour Notebook Consultant
    I just received my caddies. I ordered a hdd caddy and an external usb caddy to put my DVD in it. Total cost 15,90$ including combined shipping.
    I put my Vertex in there but I can't make it boot. When I press F9 the only option that I get is Notebook Hard Drive. Anybody booted from the caddy successfully?
    My system is an 4530s H65. When I have my DVD in it it shows a boot option Notebook Upgrade Bay, but when I insert ODD caddy with ssd nothing
    Pls advise...
    4530s will take any 12.7mm hdd caddy
  10. JKleiss
    JKleiss Notebook Evangelist
    Put the SSD in the bay the hard drive is in currently, install windows onto that. Put the old HDD into the caddy aftwards or might try boot from that.
