DIY: Adding SSD or HDD storage using an optical bay caddy
Discussion in 'Hardware Components and Aftermarket Upgrades' started by User Retired 2, Jun 9, 2009.
  1. krizzz
    krizzz Notebook Enthusiast
  2. jhl1989
    jhl1989 Notebook Consultant
    So this doesn't work on laptop such as the Samsung Series 7 Chronos?
    Because I replaced my 750GB 7200RPM HDD for a SDD and if I could use this optical bay caddy I can use both. Right?
  3. krizzz
    u should, altho i heard that some caddys does not support 500+ gb drives as they eat more power and caddy wont b able to support it.
  4. nbruser
    nbruser Notebook Consultant
    this is not true.
    the only factor for 500+ gb drives is the size of the caddy.
    the thickness of the drive is 12.5mm
    i'm using 1tb drive in the caddy - it just works fine.
  5. jhl1989
    Could someone tell me if the optical bay caddy trick works on the Samsung Series 7 Chronos?
  6. Fintan
    Fintan Notebook Consultant
    Sorry to say it, but you are shooting in the dark.
    Small chance there is someone following this thread actually owning this model!
    But personally I would take my chances.
    I think it is safe to say the caddies work for the 95% of us (probably more).
    It's not such an expensive bet either. :p
  7. thtvn
    thtvn Newbie
    I just wonder in your situation, put SSD or HDD to the caddy is getting better performance? I think you can swap, right?
    Sent from BlackBerry using Tapatalk
  8. DC87
    DC87 Notebook Consultant
    Pretty sure I have read that it's typically better to have the SSD in the main HD bay as the optical drives sometimes do not support full SATA speeds.
  9. pengy_666
    pengy_666 Notebook Evangelist
    Hi all, Huge thread. Interesting read.
    Ive got hold of a caddy for my Acer aspire 6920g. I wondered where you guys recommend getting fascia plates from.
    I cant find a second hand one :(
  10. whateva123
    whateva123 Newbie
    Is the frontplate not removable?
