DIY: Adding SSD or HDD storage using an optical bay caddy
Discussion in 'Hardware Components and Aftermarket Upgrades' started by User Retired 2, Jun 9, 2009.
  1. trvelbug
    trvelbug Notebook Virtuoso
    i was actually planning on upgrading my hdd in the caddy to 1tb hdd hence my interest in this topic.
    i really cant remember if someone in this thread has actually used a 1tb with a caddy but i guess it wouldnt hurt to ask newmodeus' customer support.
    ive had two caddies. the first one exhibited intermitent connection/disconnection issues and heating (hwmonitor) until it eventually failed after a day. the new one works fine.
    i would start out by trying to reseat your caddy, backreading this thread to see if others have gotten a 1tb working, monitoring your hdd temps and contacting newm support.
  2. Pzkfw5
    Pzkfw5 Newbie
    I actually contacted Newmodeus ages ago about it, but their response was quite limited.
    Beyond adjusting the power options in Windows 7 (which achieved nothing), I'm abit at a loss on it all.
  3. nbruser
    nbruser Notebook Consultant
    what kind of Newmodeus caddy are you talking about?
    SATA-SATA-B or SATA-PATA-B ?
  4. User Retired 2
    Studio 1535 uses a GM965 chipset with ICH8M IO. It's optical drive has a PATA controller, so your caddy would have a sata-to-pata bridge on it.
    The ebay caddy uses a Marvell and the newmodeus uses a Sunplus bridge.
    A 2510P has had better success with the ebay caddy as explained, something I'd suggest you try.
  5. gvo
    gvo Notebook Enthusiast
    Very helpful post. Thanks
  6. Pzkfw5
    Pzkfw5 Newbie
    Hello, Thanks for your post. Although the post you linked perfectly explained the problem I had, the caddy I got was a OBHD-SATA12-SATA-NF which is Sata to Sata?
    I've checked the DVD drive I've removed and some online instructions and I'm pretty sure it's a Sata connected device. Is there any tests I can do to determine where the problem lay?
  7. HeavyLoader
    HeavyLoader Notebook Enthusiast
    Hi guys, I currently own a HP Pavilion DV5-1034tx and I'm interesting in swapping out the ODD for a HDD Caddy. I did a search through this thread but couldn't find anyone with the same laptop as mine (either that or my searching skillz leave much to be desired).
    Newmodeus is too expensive so I'm going the eBay route. My ODD enclosure should be 12.7mm high, and my chipset is ICH9M. So I'm looking at a sata-to-sata one?
    12.7mm sata caddy | eBay
    How do I know that the caddy I'm buying will be compatible? I really don't wanna screw up here :(
    Edit: Did a bit more checking, here's what i'm using -
    optiarc dvd rw ad-7561s ata
    Dumb question - Is this SATA ? I read the HP DV5 service and maintenance manual but none of my laptop specs are listed there (Not even the P7350 CPU).
  8. trvelbug
    try to google a pic of a sata connection just to make sure.
    for the caddy itself just make sure it is a sata-sata caddy. many sellers advertise it as sata but is actually sata out and ide in or vice versa. read the descriptions very carefully
  9. HeavyLoader
    Dismantled and took a photo -
    Sure looks SATA-ish to me :)
    Now all I need to do is find a reputable eBay retailer who won't screw me over. Anybody with any suggestions ? :confused:
  10. trvelbug
    i bought mine over a year ago and i cant remember my seller.
    just do the usual due diligence by checking the reputation , how long theyve been in business, customer feedback, and shoot them a few emails.
    where are you from? your customs/postal service is also a factor in this.
