Ditching Macbook Pro 13" for something Lighter
Discussion in 'What Notebook Should I Buy?' started by Onikage, Aug 24, 2019.
  1. Onikage
    Onikage Notebook Enthusiast
    Hi guys! I currently have a 2016 Macbook Pro 13", which for the most part meets my needs. It's just too heavy! At 3 pounds I know that sounds ridiculous, but hear me out. My primary use case for this system is as my travel system. I travel quite a bit for work and leisure while lugging it around. When it's in a backpack with the charger and other random bits, that adds up. I'm hoping to shave at least a pound off my laptop weight.
    I'm a cyber security professional and mainly use this for surfing, hacking tools, and running virtual machines while I travel or compete in hacking competitions.
    Thanks!
    General Questions
    1) What is your budget?
    I should keep it below $1000 USD, but I will spend more if I find the unicorn.
    a. Ultraportable; 10" - 12" screen
    c. Thin and Light; 13" - 14" screen
    3) Which country will you buying this notebook?
    USA
    No
    Sure
    Penetration Testing, Hacking Competitions, running 2 virtual machines at once, productivity while traveling (This would be a secondary laptop)
    Traveling with it.
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    No
    The more, the better.
    Buying online is OK.
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows or MacOS is fine. I have a Macbook Pro 13" 2016, but honestly it's too heavy for huffing around with other gear.
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Higher is better.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    Doesn't matter.
    Build Quality and Design
    Not really.
    Notebook Components
    15) How much hard drive space do you need?
    256 GB is fine. I can probably get by with 128 GB.
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    If I find the right one, I'll get it right away.
    17) How long do you expect to use this laptop?
    A few years.
    18) How long could you afford to do without your laptop if it were to fail?
    Not a concern.
    19) Would you be willing to pay significantly extra for on-site warranty, or would it be acceptable to you to have to ship the laptop to the vendor for repair with perhaps a week or more outage?
    Shipping is fine.
  2. ZaZ
    The LG Gram comes to mind.
    JRE84 likes this.
  3. redwolf2x
    redwolf2x Notebook Geek
    I 2nd the LG gram that is a fairly light system
    JRE84 likes this.
  4. hfm
    hfm Notebook Prophet
    I would agree there. The 13.3" Gram is 2.1lb, I have the Gram 17 (3lb) and love it.
    JRE84 likes this.
  5. JRE84
    JRE84 Notebook Deity
    that definetly the way to go, ge force now and stadia for some games on your ultrabook and a egpu setup for more intense gaming sessions.....that would be my dream setup
    hfm likes this.
  6. Vingard
    Vingard Notebook Consultant
    Dare I say Huawei?
  7. Onikage
    LOL! No.
