Disc tray vibrates like crazy with a couple discs
Discussion in 'Asus' started by leftisthominid, Feb 26, 2012.
  1. leftisthominid
    leftisthominid Notebook Guru
    When I loaded my Day of the Tentacle and Tales of Monkey Island discs (the former a CD the latter a DVD) into my BD-RE on my N55SF, I got a lot of vibration from my computer. The Tales of Monkey Island DVD produced more vibration.
    I've tried other discs include my Inception Blu-Ray disc and have not seen such crazy levels of vibration. Has anyone else seen similar vibration problems from ASUS disc drives?
  2. bensmith0212
    bensmith0212 Notebook Consultant
    I have had this happen with my hp laptop, don't really know what the issue is though.
  3. ClearSkies
    ClearSkies Well no, I'm still here..
    This symptom is caused by a disc that is either out of balance, or slightly warped.
    When accelerated up to speed in the drive this induces wobble, which creates the downstream symptom of vibration and/or noise.
    In rare cases of a problem with the drive mechanism or tray, the symptom is constant and similar across all inserted discs.
  4. ALLurGroceries
    ALLurGroceries   Super Moderator
    In general a DVD will spin slower than a CD-ROM disc, and a BD slower than a DVD, so it may have something to do with the speed of the motor.
    Some vibration is normal, but I'm sure you know that. ;) The obvious thing is that it shouldn't be pulsing when it's not seeking.
  5. leftisthominid
    Well, the Tales of Monkey Island DVD spun really, really loud, but several other DVDs did not. The Day of the Tentacle disc is really old, it did vibrate as loud, but it might have been because it was reading from a the drive and copying straight to my HP Touchpad.
    No other disc I've tried including some more Blu-Rays created such a ruckus. I guess the most parsimonious explanation is that those discs are a bit warped.
    UPDATE: Per visual assessment of my ancient Day of the Tentacle CD, it was covered with scratches.
