Disc drive not showing up on 'my computer' help please
Discussion in 'HP' started by skerryman, Sep 16, 2008.
  1. skerryman
    skerryman Notebook Consultant
    For some reason my Optical Drive is not showing up in 'my computer'. Checked in device manager and there is no DVD/CD-ROM drives showing up in there either. This happened before and HP told me to delete the upper and lower filters in the registry which solved the problem but now the drive has disappeared again. Does anyone out there know how I could solve this.
    Oh yeah, its a dv9000 and I'm running Vista Home Premium.
  2. Andy
    Andy Notebook Prophet
  3. skerryman
    Tried that but the filters are not showing up so must be still deleted since earlier
  4. Andy
    Can you see the ODD in the BIOS and in Disk Management ??
  5. Cal68
    Cal68 Notebook Enthusiast
    you can use Tweak UI. it will have the drive options.
  6. skerryman
    Not sure how to check it i Bios. But Disc management just says 'NO MEDIA' for the optical drive. Downloaded Tweak VI but not that familiar with it.
  7. Andy
    Ok, if you put in a CD/DVD into the ODD, what does Disk Management say ?
    When booting, press F2 or whatever key you press to access the BIOS, and check if the ODD is listed or not.
  8. deeastman
    deeastman Notebook Deity
    To the OP, on HP notebooks press F10 during POST (during boot or reboot) to access the BIOS.
  9. skerryman
    My optical drive just reappeared a while ago and now its gone again, I guess thats why it said no media earlier. Now in disc management the optical drive doesn't appear at all. I don't see it anywhere in the BIOS either.
  10. Andy
    Try removing it physically, then re-connect it.
