Disabling awful power cord beep?
Discussion in 'Acer' started by aoeud, Jan 29, 2010.
  1. aoeud
    aoeud Newbie
    Yesterday I purchased an Acer Aspire 5740 laptop, which I quite like except for the awful beep it makes when the power cord is plugged in or removed from the laptop. Is there any way to disable this beeping sound?
  2. Mooly
    Mooly Notebook Evangelist
    Lol... now how often do you keep connecting and disconnecting with it powered :)
    It's a good reminder anyway, what if you were on battery, plugged in and had forgotten to have the adapter connected to the mains... you wouldn't know 'till the laptop shutdown that there was a problem.
    I'm guessing if there is a way it will either be in "sounds" (right click the speaker icon in the tray) or the BIOS perhaps ?
    Never known anyone want to turn it off before.
  3. aoeud
    aoeud Newbie
    It's not in either place.
  4. Mooly
    Hmmm, in that case I've no idea, sorry.
    Be very interesting to know if it can be done though :)
  5. prikolchik
    prikolchik Notebook Evangelist
    This is in XP, but should be pretty similar in Vista/7.
    Open "Device Manager" and go "View"->"Show hidden devices" then scrolls down to "Non-Plug and Pllay Drivers" click on the "+" and rightclick on the item that says "Beep". Then select "Disable" and restart your computer. Beep should be permanently disabled :D
    If you do not see the beep there, or it doesn't disable it, then you will have to check Acer ePowermanagement (or whatever it is called) and see if there is something like "beep when power disconnected".
    Anyway, good luck!
  6. aoeud
    aoeud Newbie
    I appreciate the help, prikolchik; however, I didn't get any love from that. I e-mailed Acer and hopefully they'll help (not sure why I didn't do this first)
  7. Mooly
    Let us know what the outcome is :)
  8. regulator207
    regulator207 Newbie
    ok so i've been down this path and have emailed and called acer about this. They state there is no way to disable the sound as "it is enabled by default." lame excuse but that's what they say.
    I did notice that if you dont install the realtek audio drivers, then the beep doesnt happen. Also the disable beep in device manager doesnt work in win7 and the "levels" option in the sound is nonexistant in win7.
    The audio beep goes away when you mute the system. easiest way would be fn+f8
  9. woody189
    woody189 Newbie
    I subscribed to find to this forum to solve this very problem, but decided to do a search first. I think it's ridiculous that you can't turn the sound off. It's not that serious, but it's annoying, and pretty damn loud.
    I don't get how you can adjust basically every other sound, but they would omit an adjustment for this one.
    Mooly, I don't unplug it all constantly, but I tend to plug/unplug it every couple hours because I don't like to overcharge my battery. Whenever it maxes out, I unplug the chord. Then when it's gonna die again, I plug it back in. I never leave it plugged in when I"m not using it. I heard years ago that overcharging stuff kills the battery. IDK if it's true anymore, but I still do it.
    ANyway, back to the topic... Acer's stupid for not allowing us to disable the sound.
  10. Mooly
    Just a quick point on the battery... you won't overcharge it leaving it connected and on.
    LiOn cells are destroyed quickly by trickle charging, so as soon as 100% is reached the charge is terminated. If you don't use the battery it will be perhaps 2 to 5 days before the charger again "tops off" the battery to replace charge lost by natural chemical processes in the cells. THis usually happens when the battery is around the 96% full mark.
    You are best just ocasionally using the battery... perhaps every two to three weeks or so with occasional fairly deep discharges.
    Using the battery constantly "wears" it out :) They have a fairly well defined and limited number of charge/discharge cycles from new.
Similar Threads - Disabling awful power
  1. StormFalcon
    8
    717
