Diffrence between 2070S Max Q and 2080S Max Q worth it?
Discussion in 'Gaming (Software and Graphics Cards)' started by AndresHdz, Aug 4, 2020.
  1. AndresHdz
    AndresHdz Notebook Guru
    So the 2070S MQ is a better choice?
    Many other people also told me that...
  2. saturnotaku
    First of all, use the multi-quote button if you wish to respond to multiple people. Don't create separate posts.
    You're looking at this the wrong way: It costs 20% more for just an 8% performance improvement.
    AndresHdz and JRE84 like this.
  3. Charles P. Jefferies
    Sometimes I have a hard time telling apart the Max-Q versions of the RTX 2070 Super and RTX 2080 Super in benchmarks. The same was true of their non-Super predecessors. I'd stick to the RTX 2070 for that reason unless the RTX 2080 is a free upgrade.
    Charles
    AndresHdz likes this.
  4. AndresHdz
    Ooh, interesting POV, hadn’t considered it that way. It’s now more clear that it may not be worth
    edit: sorry, I didn’t see the multi quote, I will use it in next answers
    Prototime likes this.
  5. AndresHdz
    The only RTX 2080S Max q here in Mexico at the same price range is also an MSI GS66 but with an i7-10750h and the 2080S MQ, in which I would loose a lot of processing power that I could use for my rendering/Unreal engine needs, don’t you think so?
  6. hfm
    hfm Notebook Prophet
    Existing GPUs are not going to suddenly be unusable, you'll still be able to get years out of a 20 series as long a you don't have to have the absolute latest and greatest.
    Starlight5, AndresHdz and saturnotaku like this.
  7. saturnotaku
    Not sure if it's available in Mexico, but there's the Eluktronics MAX-17, which has the i7 10875H and a full 115W RTX 2070 Super. Eluktronics in particular hardware modifies the GPU so it can pull even more wattage so you'll get an even bigger performance bump. It's a 17-inch model, but its form factor is surprisingly close to that of a 15. It's also remarkably thin and very light for its size. If this model is not available, the same chassis is also used in the Maingear Element 2-EL3, and I know they ship internationally.
    AndresHdz and hfm like this.
  8. AndresHdz
    I have checked out a lot of options and sadly I can only buy a laptop from Mexican stores, why? Well importation laws suck here in Mexico and many companies ask you to fill in many papers and permits in order to ship here. That process and a tax of 19% from the whole product I have to pay to bring it here is what stopped me from buying a Sager, Eluktroniks is a company that simply decided not to ship Mexico
    unlogic likes this.
  9. JRE84
    JRE84 Notebook Deity
    last time I checked 99 percent of games were ports. maybe im wrong but i think games will be more demanding than ever before and the current 2080 wont cut it...maybe at 1080p will be fine but 4k no way.
