Difference between U46E-RAL7 and U46E-BAL7???
Discussion in 'Asus' started by CraZySteve, May 2, 2012.
  1. CraZySteve
    CraZySteve Newbie
    Hi All,
    Newbie to Laptop forums - I came across these 2 ASUS laptops and both seem great but obviously a $100 savings is $100 bucks!
    So I am Looking at either the U46E-RAL7 ($699 OfficeDepot) or the U46E-BAL7 ($799 @ BestBuy). I left out some specs (webcam / speakers as I don't care about those... )
    ASUS U46E-RAL7 Laptop Computer
    14" LED-Backlit Screen
    2nd Gen Intel Core i7-2640M CPU @ 2.80ghz
    8GB DDR3 SDRAM
    750GB 5.4K HD
    Win7 Home Premium 64bit
    802.11b/g/n WiFi 10/100/1000 Ethernet
    DVD+/-RW DVD-RAM
    1 USB 3.0; 2 USB 2.0; 1 Ethernet; 1 HDMI; 1 VGA 15-pin D-sub
    ASUS U46E-BAL7 Laptop Computer
    2nd Gen i7 CPU @2.8GHz
    14" Display Widescreen LED-backlit
    Cache Memory 4MB on die Level 3
    8GB DDR3 SDRAM
    750GB HD
    Double-layer DVD±RW/CD-RW
    Digital media card reader
    Graphics UMA
    Networking Built-in 10/100/1000 Mbps Fast Ethernet
    Wireless Networking Wireless-B+G+N
    USB Ports 1 USB 3.0; 2 USB 2.0
    HDMI Output Yes
    OS Windows 7 Home Premium x64
    Wireless Capability 4G WiMAX
    Initially the specs look EXACTLY the same but in the end the only difference I can see in the specs is that the RAL7 only has 802.11b/g/n WiFi while the BAL7 has 4G WiMAX... I think for $100.. I DO NOT NEED WiMAX ... any thoughts
    Thanks in Advance
    -Steve
