Difference between Core Duo and Core 2 Duo???
Discussion in 'Dell' started by bjdelro, Jul 29, 2006.
  1. bjdelro
    bjdelro Notebook Consultant
    Hi guys,
    what's the difference between Intel's core duo and core 2 duo? Are theses two one and the same or not?
  2. dizzydxz
    dizzydxz Notebook Geek
    read my post from 2 minutes ago...
    basically core 2 duo is faster, 64 bit, more energy efficient... however, i am not sure if it's worth the xtra dinero...
  3. bjdelro
    I see, is the core duo the 32bit one? Sorry for the ignorrance :)
  4. qsimpson
    qsimpson Notebook Evangelist
    Intel Core Duo is 32bit yes, Core 2 Duo is 64 bit - use the search function theres like 1000 merom/core2duo threads they will answer your questions more thoroughly
  5. Jason
    Jason Overclocker NBR Reviewer
    Core Duo 2 offers 3 different advantages over regular Core duo. For one Core duo is 32 bit and Core duo 2 is 64 bit. Core duo 2 CPU's are 20% faster per clock. They also have more cache 4MB's vs 2MB's.
  6. bjdelro
    Oh i see, thank you guys. Is there any core 2 duo on dell's notebook line-up? Particularly on the inspiron series?
  7. streather
    streather Notebook Evangelist
    i don't think dell are stocking notebooks with the core 2 duo yet but i "think" you can upgrade them but dont quote me on that
  8. NYCscorpio2000
    NYCscorpio2000 Notebook Consultant
    Be aware some of the Core 2 Duo processors only have 2MB cache (the slowest 2 or 3 of the bunch).
  9. Gautam
    Gautam election 2008 NBR Reviewer
    Core 2 Duo can be dropped into a Core 1 slot, assuming BIOS will read the former. The notebook Core 2 is supposed to be a lot more energy efficient (which translates to less heat generated) as well as what others have mentioned, about bit-processing and cache
  10. Jalf
    Jalf Comrade Santa
    That's only two advantages. The amount of cache isn't an advantage in itself. It just contributes to overall performance, which you already mentioned. :)
