Difference b/w Intel Pentium Dual-Core and Intel Centrino Core Duo?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by ess_a, Jun 23, 2007.
  1. ess_a
    ess_a Newbie
    This question is really bugging me and am unable to decide on my new lappy.
    What IS the difference between Pentium Dual Core and Centrino Core Duo?
    The only thing I have come to know is that Pentium Dual Core has 1MB L2 Cache while the Core Duo one is 2MB L2 Cache.
    Would this cause a noticeable decrease in the Pentium Dual Core machine's speed?
    And which one would be cooler and better to work with?
    I have seen many resellers that claim Pentium Dual Core as the same as Centrino Core Duo. Are they right, in terms of their performance?
    Core Duo is costing more than Pentium Dual Core and for some strange reason there are not too many lappies with Core Duo here in India. Most are either Pentium Dual Core or are Core 2 Duo..
    Help!!
  2. Kdawgca
    Kdawgca rotaredoM repudrepuS RBN
    An higher L2 cache will help you in help you in CPU intensive apps like encoding/video and photo editing/number crunching/businessapps ect but a good amount or ram and a fast(5400rpm or 7200prm) helps too.
    Also most PDC have a FSB of 533mhz while C2d have 667mhz which would also result in a performance loss.
    The Pentium DC is a budget processor which is suited for office apps/word proccessing/basic multitasking/web surfing ect.
  3. ps2cho
    ps2cho Notebook Evangelist
    Pentium D series runs a lot hotter and consumes more power than the C2D's.
  4. ess_a
    ess_a Newbie
    But isnt the Pentium series for desktops (or was suppossed to be for them)?
    And the Centrino was for laptops. Would there be any problem with the Pentium in terms of reliability?
    I would mostly be needing it for web surfing, PPTs, movies and occasional games like GTA or Age of Empires III...
  5. compsavy
    compsavy Notebook Deity
    FOr what you are doing the Pentium Dual Core will suffice. I read somewhere that Pentium Dual Core is just the new name for Pentium D, yet intel had redesigned it for better performance and cooling
  6. Kdawgca
    Pentium Dual Core is just a name. It has not relation to Desktop processors. IMO its a just another name for Celeron(M) since it also had a reduced L2 cache and was also considered a budget processor.
    Since your gaming make sure your GPU(video card) can handle those games.
    http://www.notebookreview.com/default.asp?newsID=3484
  7. ess_a
    ess_a Newbie
    Thanx for the link!:)
    Right now am basically confused between three notebooks:
    1) Toshiba A100-1301D with Pentium Dual Core T2080, 1.73GHz and 512 MB RAM. Vista Basic.
    (Not very interested in this because of Vista, 512MB RAM)
    2) Compaq 6211 with AMD Turion X2 TL-50, 1.6GHz, with 512MB RAM. Vista Basic.
    (Again the same problems as above PLUS the AMD heat and speed issue)
    3) Compaq 3335 with T2080, 1.73GHz and 1 GB RAM. Vista Basic.
    (Better choice than Toshiba only coz of the 1GB Ram. But as this is more expensive, in the same price I can upgrade the Toshiba's RAM to 1 GB as well)
    4) Toshiba M100-1121D with Centrino Core Duo T2250, 1.73 GHz and 1 GB ram. XP Home
    Now this lappy suits me the best. It has XP Home as well 1 GB ram. However it is costing me 140-150$ more (converted to US currency) than option (1).
    Want to know whether
    1) RAM can be easily upgraded? Is it a DIY?
    2) Can I replace Vista with XP conveniently?
    3) Hope there are no issues with the cheaper Pentium Dual Core.
  8. Kdawgca
    Yes ram is easily upgradeable. those models should have ram cover slots at the bottom. Basically you turnoff and take out battery and flip it over(you should see the bottom of the laptop). Then find the Ram cover slot(rectangular lid with 3/4 screws) Unscrew it and pull the clips away from the ram(outward) to remove the ram.
    You can upgrade to 2gb(1gb in each slot[2 slots] total. CD/C2d/Pdc take PC5300/PC5400(same thing just diff name) DDR2-667 200pin So-dimm or PC4200/PC4300 DDR2-533 200pon So-dimm
    To replace Vista with Xp you would need an XP disc and then you would just reformat the Hard drive and isntall XP just you might have problem finding device(sound/keyboard/ect) drivers
    There shouldn't be any issue unless you plan to do some intensive CPU apps.
  9. System64
    System64 Windows 7 x64
    Does Pentium Dual Core have SpeedStep? If it has, it should be a great competitor to Sempron.
  10. ess_a
    ess_a Newbie
    Sorry for being totally ignorant, but what is Speed Step?
