Diagnose touchscreen problem on CF19
Discussion in 'Panasonic' started by ToughMobileMan, Oct 14, 2015.
  1. Shawn
    Yep, I caught your error but I let you slide this time.
  2. ohlip
    ohlip Toughbook Modder
    This unit known for good quality touchscreen panel but I have one unit acted like that and what I found is that the circuit bridge/ connection between the glass assembly and the ribbon cable start to separate due to heat. Different story though on CF-30MK1, CF-18, CF-29 and CF-19Mk1. It can be cured by a mildheat also but it require a disassembly of the LCD panel to access to those area.
    ohlip
  3. ToughMobileMan
    ToughMobileMan Notebook Enthusiast
    Just following up; once you do a few, you can do them in under an hour. Thanks to everyone for their help.
  4. 1517
    1517 Notebook Guru
    Hi if it has GPS unit it is probably the serial mouse needs to be disabled in device driver and do the gps registry fix.
  5. ToughMobileMan
    Anyone have a good source for Touchscreen panels? Seller "TechStuff" on ebay is currently out.
  6. Shawn
    How many?
    What mk?
  7. ToughMobileMan
    2 Screens. MK4
  8. SHEEPMAN!
    SHEEPMAN! Freelance
    I bought a bulk (10pc) order from China once upon a time. They were o.k.
    If you can get a message to techtuff maybe he has some insight on a vendor.
