Dell's 7970M in P370EM
Discussion in 'Sager and Clevo' started by Rebkos, Jan 11, 2018.
  1. Rebkos
    Rebkos Notebook Enthusiast
    Hello, I have in my P370EM Clevo's 7970M v1.1, which I have baked several times and which is the reason why I bought another 7970M (sadly Dell v1.2).
    After flashing the new Dell card's vBios with latest Clevo 7970M vBios from techinferno I am able to run it in master slot, even crossfire is running.
    BUT, no HDMI whatsoever. DP only without audio. When I flash Dell vBios to it I get no HDMI and no DP.
    Anyone managed to run Dell's 7970M v1.2 in P370EM (or another Clevo) with fully working HDMI and/or DP with audio? Any recommended vBios?
  2. Rebkos
    Bump?
  3. Meaker@Sager
    If you have tried the native vbios then it's likely a clash in the HDCP setup and I have not heard of it being fixed.
  4. Rebkos
  5. KY_BULLET
    KY_BULLET Notebook Evangelist
    I tried one of these when I upgraded my D900F from a 280m to Eurocom 680m.
    It was supposed to bypass HDCP but unfortunately it didn't.
  6. Damin
    Damin Notebook Geek
    As far as I know with the 7970m the Dell card just NEVER works from what I remember it's a physical hardware issue not even a flash will help..but if you manage to do it I will keep a eye on this thread
  7. Rebkos
    The card it self works in P370EM. Even in crossfire with 2nd card being baked clevo v1.1
    But i am unable to make HDMI work. DP is working on some vBios, but sadly without audio.
  8. Damin
    Damin Notebook Geek
    There was always a HDMI issue with The AMD cards this could be that issue ..I have the exact laptop at home all Clevo If you want me to do a test or 2
    The
  9. Meaker@Sager
    What if you use it as the secondary card and use the other for display outputs?
  10. Rebkos
    That would work. But I bought the new secondary card, because my old primary 7970M has been baked more than 8 times already. And I wanted to make my P370EM more reliable again (because other than the gpu issue, it works quite well [exclusive of battery, for obvious reasons - 5+ years old]).
    So yeah. I could use the old card in master slot. But that would be against my primary goal, why I even purchased this card.
    Thank for your input though ;-)
