Dell XPS Speed Shift
Discussion in 'Dell XPS and Studio XPS' started by pressing, Oct 8, 2016.
  1. pressing
    pressing Notebook Deity
    I'm not an expert but I have read that both EIST & SST can be activated simultaneously and the processor & O/S sort out the processes. But EIST is really laggy.
    Turbo requires SpeedStep and C3 (plus C6?) states to be enabled in BIOS. The work around I use is via ThrottleStop. In BIOS I have both SpeedStep and C-States enabled. Then in ThrottleStop, I disable laggy SpeedStep but top turbo speeds remain. In ThrottleStop I disable the very laggy C1E States. There I also enable SpeedShift. These settings are verified in HWiNFO64.
    EDIT - To be clear, real-time audio performance improved when I disabled C-States in BIOS. But that disabled the turbo and the processor maxed out at 2.2GHz. By enabling C-States in BIOS but killing laggy C1E states in ThrottleStop, I got the best of both worlds: turbo performance and removed the problematic C-States.
    I never found a way to disable SST without turning off the computer. That said, the large Intel PDF on the first post might give you some insight.
    For improved performance in real-time audio, I also noticed a difference turning off anti-virus software. Not via settings which didn't help. But in W10 pro going to Local Group Policy editor and "enabling" "turn off windows defender". I also tried removing Windows Defender for another lightweight antivirus program but that did not help. Use caution without internet!
    Thanks for the insightful summary arshcaria!
  2. GoNz0
    GoNz0 Notebook Virtuoso
    Well we have been told enabling speedshift in throttle stop can be done but turning off can't so I expect this is a reboot to disable job.
    As for entries in the power plan I assume windows checks what is available during install and adds the features, maybe someone due to reinstall can confirm this.
  3. Techland
    Techland Notebook Consultant
    That might be. But obviously then Dell still has a reason not to enable/add this feature, as the majority of existing customers do not get those controls.
  4. Techland
    pressing, thanks for the detailed explanation.
    Yeah, Windows Defender is a terrible performance brake. I configured its settings to not scan many things, including a lot of programs where it multiplies the start time (compressed exe) significantly. One day I might go back to Avira, where I never had these problems for the last 6 years.
  5. GoNz0
    I disable defender by group policy or it is never totally turned off, it's worst than a bloody virus!
    pressing likes this.
  6. arshcaria
    arshcaria Notebook Enthusiast
    I just did a performance test with different EPP values.
    The test is done via building an Android project using Android Studio and measuring the consumed time.
    Building Android projects involves reading/writing/compiling a huge amount of files so it can properly test the burst performance of different EPP values of speed shift.
    Code:
    EPP       0           128        192        224         255
    #1        4.614       5.04       7.697      11.615      13.657
    #2        4.518       5.69       7.842      11.641      13.932
    #3        4.366       5.006      7.679      12.067      13.735
    #4        4.27        5.025      7.859      11.899      13.6
    #5        4.239       4.915      7.708      11.92       14.023
    avg        4.442      5.190      7.769      11.806      13.731
    ratio      1          0.856      0.572      0.376       0.324
    Time unit: seconds
    Hope this can be a guideline of choosing desired EPP values with proper tradeoffs.
  7. goodwin_c
    goodwin_c Notebook Enthusiast
    As expected, between 0 and 128 there is no so much difference, but not bad battery saving. After 128 more aggressive power saving begins.
  8. pressing
    Arshcaria,
    That is an interesting set of statistics - thanks for taking the time to run them.
    Did you run them with both SpeedShift & SpeedStep enabled? You can see that in HWiNFO64. There were some interesting related questions on the ThrottleStop Guide thread (I think). For example:
    1. how do SpeedShift and SpeedStep interact? When SpeedShift runs, does SpeedStep get superseded, does it positively-neutrally-negatively impact performance?
    2. How do performance of SpeedShift vs disabling C-States compare?
    If you have some extra recreational time, maybe you could run a few quick independent scenarios testing:
    1. Try disabling SpeedStep by unchecking that box in ThrottleStop
    2. Try disabling C1E in ThrottleStop. Those C-States seem to cause a lot of performance issues
    3. Try fully disabling C-States in BIOS
  9. arshcaria
    Not sure how SpeedShift and SpeedStep interact, a pure guess is that SpeedStep is overridden when SpeedShift is enabled.
    In my test, setting SpeedShift EPP to 0 and disabling C-States give identical performance.
    1. Once you have enabled SpeedShift, disabling/enabling SpeedStep in ThrottleStop won't make any difference to the CPU frequency.
    2. Haven't tried that, maybe later I will.
    3. Haven't tried that, maybe later I will.
  10. pressing
    This is quite interesting! For my real-time music app you can see above that I had some differences.
    Let us know if you have the opportunity
    Thanks!
