Dell XPS Speed Shift
Discussion in 'Dell XPS and Studio XPS' started by pressing, Oct 8, 2016.
  1. Rockstar75
    Rockstar75 Notebook Geek
    It´s really nice if enabled in BIOS. The dropdown menus in the processor power plan pressing "revealed" in the first post here are now working fine. Give it a try :)
  2. GoNz0
    GoNz0 Notebook Prophet
    Yep I have just been tinkering with those with HWinfo64 running in the background, you can see the processor basically sat at 3.5ghz with the energy performance preference at 0%
    I left it at 50%
    pressing likes this.
  3. Rockstar75
    Right, that was my experience, too. For the power plan on battery I put it to 60, I think. Don´t know if it was much of an improvement. But it´s fine to get it integrated in the system without having to use additional Software. I for myself have to wait till we get to know the variables for the 9560.
  4. goodwin_c
    goodwin_c Notebook Enthusiast
    You are welcome :) Just trying to fix Dell stuff... I'm working closely with Hackintosh project for this laptop - you can't imagine how much problems dell "features" are bringing...
    GoNz0 likes this.
  5. goodwin_c
    @Rockstart75
    I know that this is little bit faster that i promised :-D But just accidentally found all needed tools around in my lappy (i thought i moved them already somewhere), so there is info for 9560
    Code:
    0x3F50B             Setting: Intel(R) Speed Shift Technology, Variable: 0x4BC {05 91 B6 01 B7 01 D3 01 01 00 BC 04 10 10 00 01 00}
    0x3F51C                 Option: Disabled, Value: 0x0 {09 07 04 00 30 00 00}
    0x3F523                 Option: Enabled, Value: 0x1 {09 07 03 00 00 00 01}
    So, your variable offset will be 0x4BC and value to enable as usual 0x1 (0x0 to disable - in any case)
  6. GoNz0
    FluffyDroid likes this.
  7. Rockstar75
    GoNzO said anything neccesary :) Wow! i will try asap!
    And I did it :) It seems to be the right variable and it works great with the onboard controls. Thank you goodwin!!!
  8. pressing
    pressing Notebook Deity
    GoNz0 confirmed that EPP of 50% and 65% allow his 9550 i7 CPU to hit max speeds
    Rockstar - can you confirm if EPP of 50% allows your 9560 CPU to hit max speeds?
    __________
    Not an XPS but a new Kaby Lake CPU....
    Uncle Web recently posted that his Kaby Lake CPU speed was capped unless EPP was below 80 (80 of 255) or below 30%. You will need to check your CPU but that implies you can reach max CPU speed with EPP only in these ranges:
    0%~30% (on 100% EPP scale)
    0-80 (on 255 point EPP scale)
    [EDIT] See below:
  9. GoNz0
    Just tested it on 50 and 65 (65 is for battery) and on both it hit 3.5 on the TS bench 1 thread :)
  10. pressing
    Do you mean 50% and 65%? Or are those on confusing 255 scale?
    Is that on your 9550 (I know answer)?
