Dell xps m1530 Plugged in, Not Charging
Discussion in 'Dell XPS and Studio XPS' started by sultansaadat, Sep 20, 2008.
  1. sultansaadat
    sultansaadat Newbie
    Hi,
    I have a dell xps m1530. Yesterday, suddenly a problem developed. The laptop charges for a few secs and then the battery icon says plugged in, not charging. I have tested the power supply and the adapter pin on the laptop motherboard its working fine. I purchased the laptop 4 months ago. i am using windows vista Ultimate with sp1. What could be the problem? Any solutions for this. I tried googling it but there is no definite solution.
    Thanks,
    Sultan
  2. dell.scares.me
    dell.scares.me Notebook Consultant
    So will the laptop power on without the battery, just on AC power?
    Do you have any other batteries to try?
  3. MystiklMayhem
    MystiklMayhem Notebook Consultant
    have you tried the life button on the battery itself? (push and hold for what 5 sec?)
  4. Cin'
    Cin' Anathema
    This is *sort of* similar to what happened to me, on my 1530~!
    The battery wouldn't hold a charge...I called XPS support. They had me check the adapter from the wall outlet > to the brick > to the adapter > to the socket in the lappy. The brick stayed *positive*. Then they had me check the battery itself. Not working...It just would not hold a charge. :eek: The adapter was a bit loose inside the socket!! another :eek:!!
    So, Dell sent the on-site techn. to my house and they replaced my Motherboard, along with bringing me a new brick and adapter. ;)
    (I had figured that the internal *socket* was loose and needed some soldering & the technician also agreed) But the easiest way was to just replace the Motherboard. :)
    So, now things are working just fine...And I'm wondering if this could be happening to your 1530???? Not sure, as you stated: that the *adapter pin on the laptop motherboard is working fine* ;)
    Just my thoughts, and my own opinion :eek: ;)
    Cin ;) :)
  5. fonduekid
    fonduekid JSUTAONHTERBIRCKINTEHWLAL
    Try removing the battery completely, the ac and then reconnect both of them after a while.. say 10 or 15 mins and see if it charges up...
    Another thing is drain your battery completely or at least till the critical level... and see if u can plug in n charge then...
    Probably there is something wrong with the battery??? I dont know..
    You could ask Dell to ship u a replacement battery may be if the above things dont work...
  6. Koer
    Koer Notebook Deity
    lol this happened to me with an HP, i completely cut and restored the adapter, when i took the battery out, suddenly it started working... good thing to know, dells have the power supply power the whole system, and then the battery, the hp was the other way arround .....
  7. sultansaadat
    sultansaadat Newbie
    I took the battery out of the laptop. Pushed the button on the battery and 4 lights lit up. What does this mean? Secondly, i ran the laptop on direct AC with the adapter. So this means there is something wrong with my battery and not the pin or the power supply brick. Should i get the battery replaced as my laptop is still under warranty.
  8. fonduekid
    the battery lights are for an indication of the battery charge/health..
    I think you should ask for a replacement.. Yes its seems the battery is having some problem.
    Call Dell and ask for a replacement... and u shud get one..
  9. Cin'
    Cin' Anathema
    If you believe it's not the pin or power supply..and as it's still under warranty..I would ask for a battery replacement ;)
    Cin ;) :)
  10. fonduekid
    To the OP > and you might want to tell tech support that u tried everything possible for checking the issue.. else they might ask you to go through everything all over again... so U could just minimize the time u spend with them on the phone and ask for a replacement straight away, after telling them u checked everything and made sure its the battery.
    And just for more info (in case u haven't seen this) >>
