Dell XPS 15 9570 benchmarks + temps
Discussion in 'Dell XPS and Studio XPS' started by custom90gt, Jun 7, 2018.
  1. MSIX
    MSIX Notebook Enthusiast
    Where is this DIMM/ Ambient Sensor located? I am experiencing high DIMM temps when running Realbench Stress when only testing 4gb of RAM. DIMM in AIDA64 showing 90+ withing min of starting the stress test which either blue screens or I have to shut down.
  2. Woodking
    Woodking Notebook Evangelist
    Slap bang between the DIMM modules. Its the tiny square thing in the middle towards the top.
    You can use thermal pads to cover the DIMMS to the case if you are getting high temps, may help.
  3. MSIX
    Never experienced this previously. Not sure why all of a sudden the DIMM temps are skyrocketing. I am back at stock core/cache voltage.
  4. Woodking
    Your processor will be kicking out some serious heat being an i9, especially if you've gone back to stock voltage and it hits peak frequency. This XPS has many thermal issues it seems.
    You can tune the laptop setting in Dell Power Manager, have you got that installed? Cool disables Turbo but does do a better job at keeping the machine quiet and cooler but you do take a performance hit. Turbo massively passes the processor's TDP and as such this machine cannot cool itself out of the box without being tweaked. Unless you live in the Artic of course.
    I really hope future XPS models become a bit 'chunkier' to be able to properly deal with cooling (while staying powerful and innovative), and Dell create a new model of lightweight 'Ultrabook' types that are still pokey but are able to stay cool and quiet. Whats the point of having a really powerful machine if it cant sustain its own cooling?
  5. MSIX
    Yes I have dell Power manager installed. have always used Ultra Performance and never really experienced dimm temps above 72
  6. pressing
    pressing Notebook Deity
    As you note, "Cool" setting disables turbo speeds on my laptop but HWiNFO shows that turbo is still enabled.
    If you enable SpeedShift, turbo speeds are accessable even at "Cool" setting (with a low EPP)
  7. Brimmy
    Brimmy Newbie
    Can you please check and let me know sustained clock speeds with and without hyperthreading?
  8. custom90gt
    custom90gt Dellerator Super Moderator
    I can't since I returned it but maybe someone else can for you.
  9. zeverus
    zeverus Notebook Enthusiast
    Stock results :( Think i might need to return. throttles cpu down to 800 mhz. This is after 20 minute stress test.
    8750h, 16 ram, 500gb ssd, FHD.
    Its the ambient sensor reading 120C thats bothering me
  10. custom90gt
    That's the VRM temp sensor. Mine never got that hot, but maybe I was just lucky. Looks like either an undervolt/repaste/padding is in your future or returning the laptop.
    pressing likes this.
