Dell XPS 15 9550 shuts down after heavy usage on battery
Discussion in 'Dell XPS and Studio XPS' started by LadikCZ, Nov 8, 2016.
  1. LadikCZ
    LadikCZ Newbie
    Hello,
    i tried to search forum for following problem, but i couldnt find any related thread.
    My problem is that my DELL shuts down after few minutes when i am on battery without AC and doing some heavy usage - for example gaminng.
    When i start the laptot with power button it says, that battery is criticaly low even that it was fully charged like 10minutes ago. When i connect AC adapter it immediately shows that battery is charged for like 75% or more.
    Do someone have similar issue? Is there some solution for this?
    Thank you for answers guys.
  2. GoNz0
    GoNz0 Notebook Virtuoso
    Either a defective battery, or worst than that motherboard. Have a look at the battery health in the BIOS. Phone Dell and arrange a service to replace the battery if need be.
  3. alireza73uk
    alireza73uk Newbie
    Hi LadikCZ did you fix your xps? what was the problem?
    i have this machine for nearly a year and today i faced this problem while i was trying to get a GPU benchmark.
    my problem is a little different compared to you, when it suddenly shuts down it refuses to power on unless i plug AC in(after plugging LED blinks 2 times orange and 1 white).
  4. GoNz0
    Replace the battery.
  5. alireza73uk
    alireza73uk Newbie
    thank you for reply Gonzo
    in BIOS for battery life it says its "Excellent".
    is there any chance that disconnecting and reconnecting the battery help?
    i had this issue: https://www.reddit.com/r/Dell/comments/5uh6wo/fixing_your_dell_xps_cpu_stuck_at_minimum/
    and yesterday i used this method to fix it:
    and today faced this problem.
  6. GoNz0
    If you don't think it is the battery then google some software to monitor and log the voltages but it does look like the battery craps out under extreme load with your description.
